CNC style Pendant
@arhi said in CNC style Pendant:
@dc42 btw, can paneldue usb port behave like master to ch430/ft323/similar usb2serial device? and receive commands from there (or just passtrough to duet)?
No, it can only behave as a USB device. However, the v3 PanelDue boards have hardware connections for a rotary encoder and push button.
I am not tracking something. If we had a pendant that had USB host, with what would that interact? The USB on the Duet itself?
@Danal said in CNC style Pendant:
I asked 'cause I had an idea that if the panel can be USB host then el-cheapo usb2serial + any MCU with ADC can translate a bunch of tasters into gcode and send trough panel's "console" to duet (without them sharing serial port) ...
I am working on some stand-alone wifi pendant but it's going super slow 'cause I'm pressed with bread and butter work and looks like it will not be working with SBC "upgraded" machines + I'm really making this the way I need it so dunno how universal it will be if I ever actually make it.
@dc42 said in CNC style Pendant:
the usb2serial idea out the window
I have V3 PRC clone that I got as a gift, no other screens at all on my duet boards, I kinda prefer to use web to the touchscreen so never bothered to order some, and that one does not come with the rotary encoder+push button connector (I assume it would be Vdd, Vss, A, B, P pins).
I've written the Arduino Nano code for the pendant-to-PanelDue-port interface. Now I need to wait for the pendant and Nano to arrive so that I can test them.
@dc42 presumably this would work with any encoder? I.e. i have at least some 400/600/1200 PPR encoders in the bin and a selection of switches to mimic the quasi-schematic published with the pendant (but I guess the pendant has detents on the encoder to help with accurate positioning)
Yes it should work with any encoder that has A and B quadrature outputs.
For anyone interested in this, the pendant I have ordered looks like this:
It costs £55 here in UK shipped from Germany, or a little less direct from China. I have the Arduino Nano code ready to use when it arrives. I'm happy to share the code before then if anyone wants it, but of course it is untested.
@dc42 I can believe this is happening. Three questions, if you've got the time: could you share the link for that pendant? also, will it be compatible with the Duet 2 WiFi? and finally, is there going to be some kind or article where the build is described?
I have some Arduinos at home, a Duet driven CNC (Workbee) and I have now plenty of time with the corona stuff going on, so I could definitely work on that...
Greetings
@FelixH said in CNC style Pendant:
For other Duet users, what's needed is a a board based on a small MCU to convert the signals from something like this https://www.ebay.co.uk/itm/EU-Send-4-Axis-MPG-CNC-Machine-Controller-Handwenheel-Pendant-w-Emergency-Stop/273588909379
@bearer oh, thanks! I missed that!
Greetings
It will use the PanelDue port, so it will be compatible with all Duets that can but don't have a PanelDue connected. When I have it working (maybe even before), I'll publish the details on github.
Oh, I see. It is either the pendant or the display... well, that's a bummer. The display it's quite useful to start jobs and many other things... Anyway, I'll keep an eye on it
@FelixH If you need PanelDue also, you could consider a solution similar to SMUff https://github.com/technik-gegg/SMuFF-Ifc where an ESP32 is between and allows two devices using the interface.
@JoergS5 that's a neat project! However, I will quote Rocket Racoon on this one... "I go for the simple things"... would it be possible to just attach a switch on the UTXD0 and URXD0 pins and flip the switch to the input device you need?. It's not like I need to use them both simultaneously, I think... I guess the answer is no, but still it would be the simplest thing to do
double pole double throw switch should work without a problem for this purpose selecting one or the other device
question. are you sending many short G0 while receiving impulses from the encoder or you scan at a certain frequency (e.g. 2Hz or 10Hz) and then send G0 according to what encoder did between scans? I'm making this wifi pendant for a while now and having issues deciding what I want. First version I made with buttons, then replaced buttons with a stick but now stick is behaving like buttons (you have to move stick for each movement and select increment on other button) and I don't like it. now I'm attaching analog stick so I can use 2-3 different speeds according to the angle of the stick but again, don't know if I wanna send ton of 0.1-10mm gcode's in a loop, or do 2Hz scan and send only gcode's at that frequency. You for sure have more experience with this so know what might be better solution. I guess analog stick is similar to the encoder so decisions should be similar :). Now I'm thinking about adding encoder to the stick too (I'm never going to finish this, first screen, then stick, then analog stick, now encoder... neverending story).
p.s. I didn't want to go with "ready made pendant" as they were "expensive", now looking at %$#^^@$# I crammed in to the box it's more expensive than ebay
I've written it to accumulate movement from the encoder and send it only when the UART transmit buffer is empty. I suspect this will still be too often, and I will need to send it every X milliseconds instead, or immediately if we haven't sent a command for the last X milliseconds.
Yesterday I got my Pendant, exactly as the one pictured. I could start working on the implementation on my spare time
I'm still waiting for mine, but feel free to try my code. It's at https://github.com/Duet3D/CNC-Pendant-Firmware.
