X y motor confusion
so have x and y wired up on my large format printer im building.
when i click to move x 100 mm y moves also…
hmmmwhen i click y to move 100 mm x moves also
they are of course wired seperately..all go in to there respective ports on the wifi board etc.
EDIT: ok weird…z is not hooked up and if i click z on the screen x and y move also
any ideas would be a appreciated
It sounds to me that you are using a config.g file that is meant for a delta printer. Use https://configurator.reprapfirmware.org/ to generate new config.g and homing files.
oh snap…i think you are right
mmmk..
so i have a diff kinda build.
im using 4 motors
18x18 square.i have is kinda set up as an xy i guess..but not really
i have one motor on x…one motor on y.... 2 motors on zed
2 motors on z because it will be lifting an 18 inch bed
my question is how do i hook the two z motors up to the duet wifii did a new config file on reprap and did the cartisean.
now the axis are working properly on ax and y
moving individually
on to drilling holes in my 20x20 bed...this should be fun -
ahhh…got it...thank you sir
wiring up my end stops now
