Easier switching between DSF and Standalone mode?
@bearer said in Easier switching between DSF and Standalone mode?:
Too bad the Pi
cancan't act as a SPI slave; does the jetson suffer the same limitation?The Jetson SPIs works in slave mode in most circumstances. Unfortunately I became the SPI "expert" for the Jetsons and got a community award from nvidia for it.
@gtj0 said in Easier switching between DSF and Standalone mode?:
Thinking more about this, it's be really nice to have the Duet's DS card available while in DSF mode to maybe cache a print file instead of getting it line by line from DSF when the DSF isn't adding any value.
Except DSF actually processes quite a few of the gcodes. Non move.
@Danal Yeah but it doesn't do anything special with them. At least not at the current time. I always wondered why the DSF just didn't preprocess a print file and ship the file to RRF to print but that's a subject for another decade.
would have been a neat trick to use the same interface and just switch the SBC to emulate a SD card, but Pi's can't do that unless you get another award?
@bearer Not a chance
M23 HemeraToolPlateToolBoardHoles.gcode M24
The duet can't do that, the file would be not found. Preprocess and ship... well, then what about M20 (list), and rename and delete and so forth.
So move EVERYTHING back to the Duet. Except, run the web server on the Pi, but not the controlserver (or, probably better phrasing, the control server become a very thin interface.) Right or Wrong, this is not the path that Dave and Chris chose.
This feature is already planned for firmware 3.02.
@Danal said in Easier switching between DSF and Standalone mode?:
I'm not suggesting the current path is Right or Wrong. I was just wondering. There certainly could be benefits to having the DCS send gcode line by line. We're just not at that point yet. Like I said "...that's a subject for another decade." Given that "stay at home" has forced me to have 2 double-decker BLT sandwiches with extra mayo this week, I probably won't live that long.
@dc42 said in Easier switching between DSF and Standalone mode?:
Good news! Thanks!
If that doesn't work already (have you tried it with the latest RRF and DCS?) then I'm sure it would be possible to make it work.
Dang, man, I need to visit, lockdown or no.
