Filament-change.g
3.01-RC8 still react the same
Thanks, added to my list of things to investigate.
@dc42 Thanks, i'll overcome this when 3.02 will be here, if you need me to test it another time later, don't hesitate
@Krohm-Koala, please can you try release 3.01-RC10 and see if the problem is still present.
@dc42 i just tested it, so, it's still here, still resume and launch the macro at the same time, blocking everything.
I'm sorry, I can't reproduce this, using 3.01-RC10 on Duet 3. I had to edit your files a little to make them work on my machine, but they seem to be working. It does runs the purge macro, which asks me if I want to purge. If I say yes, it purges, then asks me again; and so on until I response with Cancel. Then it thanks me for changing the filament.
However, I did notice that the messages that don't have an "OK" button are displayed only on DWC, not on PanelDue as well.
I'm using a duet 2 wifi, maybe that's the reason ^^ if you want, maybe I can film what happened to let you see
and maybe upload my whole config files, maybe something is wrong ^^
Are you absolutely certain you are running 3.01-RC10? Send M115 to check.
Duet 2 and 3 firmware are built from the same source code, so it's unlikely that this sort of fault would affect one and not the other.
Yes absolutely sure, that's what appear in dwc and with the M115
I'll upload my whole sys/ folder and film what happens so you can see exactly what it does
Here is the video : https://vimeo.com/412688450
the config is here : https://mega.nz/file/eQpC2ayT#4tPTbsP3_YXheCTRxhzMyoEwRT6AAZKng-Vt3GKG3ck
i hope it can help
@dc42 Hi, i've tested some thing such as, different directory for the purge macro, even put it in sys folder, always the same thing... I also put it out of the filament-change.g, so in my pause.g, i run the purge.g after the filament-change.g, it does exactly the same thing... I also try without the purge, i goes really good ._. don't know why it does that ... maybe i'll try something else later if i got some idea. Maybe i should delete the config.json and config.g.bak but should do anything.
Thanks for your time
