Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?
ok ... I would test it
@ediik Hi! I came across this thing. One question - why don't you use PS_ON signal for controlling Lerdge power module?
@Meltex hi sorry for late reply. i honestly dont know how to wire it up the right way.
Don’t feel bad this module has beaten me as well for time being. I went to the solid state relay setup as highlighted above and was much simpler to get going with the same button. But... I really would like to figure this out too at some point lol.
Little correction, for me, it’s the Makerbase MKS PWC V2.0 module. No matter what I tried, just couldn’t get it to work.
Hello, did anybody the Lerdge Power Modul to work with the Duet. I want to try the same thing. Have a Lerdge Power Modul laying around here. What does the PS_ON pin on the Duet exactly? Act it like a 5v on and off switch?
@Richygoat said in Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?:
https://duet3d.dozuki.com/Wiki/Power_Wiring#Section_Controlling_the_external_power_supply
Here is no answer to this question. I want to turn the PSU off with this modul. When it get 5v continuously from the Duet it stays always on. When there is 5v, GND an PS_ON on that connector how does it exactly work. I know this is 5v in. Does the PS_ON switch the 5V to PS_ON?
Ok the PS_ON pin will be connected to Ground when the PSU have to be enabled. Is there a way to get a 5v Signal to shut the Relay down? See the picture attached.
Is something like this possible?
This is how it works perfekt. Big thanks to Eryion from Rics 3D Discord.
I edited your sketch and "connected" the switch button. Is that right, did you mean it?
And a other, next question ...
Can you turn off the printer when it is connected via web interface??? -
Yes that is correct. The 12V/24V is only for the Button LED. Yes i can turn the Printer via Web Interface off.
thanks for the info
@CrazyCreator Hello! Tell me please: what is the white line at the bottom? It is pin connection
between top left on black port and top one on the white? And the black line
between ps_on and module connects central pins?
Thank you in advance for the answer. -
@Richygoat hi, I have panel due with sd card. How i will connect this module?
