Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?
First: You mean the Wiring from the first posting?
This:Second:
What mean: (and 5V/gnd ofc)?I don't understand the "ofc"
And Last:
I can use this wiring for the rest:
Yeah, it has the S1 and S0 labels on the MKS PWC, they are the PS_ON output and PowerLoss input signals respectively.
Ok ... I read and hope I understand
For the rest of wiring I can use this picture too:
I know the picture is for the MKS Gen 1.4, but I mean the routing for the other cables
if your goal is:
- 24v supply on / off via gcode or dwc
- emergency stop switch
- reset
try this:
You only need : example for a opto low-level trigger-relay
@crazycreator Duet is able to resume after a power loss, if you set it up: https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
For powering on/off: https://duet3d.dozuki.com/Wiki/Power_Wiring and
@thwe and @Stephen6309
My only concern is to have a 16mm button on the front of the printer, with this I want to turn on the printer.If I can turn off the printer with this button, that would be nice, but it is not necessary. I can do that also via web interface
If anybody came accross the same thing i got a solution. now the baord turns ON with the front button.
Sidenote: it does not matter where you get the 5v from. The pins from the main extension ports are allready if use on my board (bltouch).
how locks your config.g now
@CrazyCreator it does not matter. The lerdge board simply gets 5v from the duet and stays on for the time it has 5v connected. No cdg changes necessary.
ok ... I would test it
@ediik Hi! I came across this thing. One question - why don't you use PS_ON signal for controlling Lerdge power module?
@Meltex hi sorry for late reply. i honestly dont know how to wire it up the right way.
Donβt feel bad this module has beaten me as well for time being. I went to the solid state relay setup as highlighted above and was much simpler to get going with the same button. But... I really would like to figure this out too at some point lol.
Little correction, for me, itβs the Makerbase MKS PWC V2.0 module. No matter what I tried, just couldnβt get it to work.
Hello, did anybody the Lerdge Power Modul to work with the Duet. I want to try the same thing. Have a Lerdge Power Modul laying around here. What does the PS_ON pin on the Duet exactly? Act it like a 5v on and off switch?
@Richygoat said in Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?:
https://duet3d.dozuki.com/Wiki/Power_Wiring#Section_Controlling_the_external_power_supply
Here is no answer to this question. I want to turn the PSU off with this modul. When it get 5v continuously from the Duet it stays always on. When there is 5v, GND an PS_ON on that connector how does it exactly work. I know this is 5v in. Does the PS_ON switch the 5V to PS_ON?
Ok the PS_ON pin will be connected to Ground when the PSU have to be enabled. Is there a way to get a 5v Signal to shut the Relay down? See the picture attached.
Is something like this possible?
This is how it works perfekt. Big thanks to Eryion from Rics 3D Discord.
