Need Help with BL Touch Set up
sorry you're having a bit of trouble. I think part of the problem is that you're using RRF3 but you've either gotten config files for using 2.x version or used some documentation for 2.x version.
First
@Shamusseven said in Need Help with BL Touch Set up:
because yes it is just a few mm to the rear of the nozzel and about 37mm to the left of the nozzel.
G31 P500 X170 Y180 Z2.5
You must change the X and Y values to match the distance between the nozzle and the BLtouch. Also change from P500 to P25.
Here's an example of how to measure it: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s230
Once you have the probe working, you will need to calibrate the Z trigger height, also described in that link.
You must change your deploy and retract macros to use P0 instead of P3. P0 reserves to servo index 0, which you created with the M950 command in config.g. In 2.x versions the P3 would have referred to the heater 3 pin directly.
M280 P0 S90 I1; retract BLTouch
M280 P0 S10 I1; deploy BLTouch
Since you are using the BLtouch with a DuetWifi, you will also need the
I1
to invert the signal.Your homeall looks fine.
AS for the Z axis direction, 0 is where the nozzle is touching the bed. 400 is when the bed is farthest away from the nozzle. Negative Z movement moves the nozzle and bed closer together, positive Z movement moves them farther apart. If that's not what's happening now, you'll need to change the direction of rotation for the motors on the Z axis.
@radekzl I removed this file and now I can’t get anything to work.
@radekzl said in Need Help with BL Touch Set up:
And check sd card if you do not have on sd card file iap4e.bin and delete it.
Do not delete that file. @Shamusseven
you can redownload the file here if need be: https://github.com/dc42/RepRapFirmware/releases/download/1.21/iap4e.bin
@Phaedrux said in Need Help with BL Touch Set up:
Since you are using the BLtouch with a DuetWifi, you will also need the I1 to invert the signal.
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
Create the deployprobe,g and retractprobe.g macros as described for using RepRapFirmware 2. The P value in the M280 commands should be your chosen GPIO/Servo index. You do not need the I1 parameter.
@DIY-O-Sphere said in Need Help with BL Touch Set up:
@Phaedrux Yes that is one of my frustrations. I started out over the weekend with 2.3 firmware but updated to 3.0. Now that I removed the one file mentioned above and nothing works, what do I do? I can’t even open the config.g file.
I'm so sorry, but I have only this two files for firmware 3.01 RC6 and everything works fine.
and all standard files .g
@Shamusseven
Are you still connected to the board over DWC? -
Nope. Totally shut out now. I added the file back to the card but now i can’t log back into my card. Tells me to check to see if my SD card is mounted correctly and it is.
@DIY-O-Sphere
I woud try to only copy back the deleted files. -
Well copying just the one file did nothing so will have to see about doing the fall back
okay I am back to being connected via wifi. I have made what I think everyone has mentioned but still not working right. I still can't get my bl to deploy probe except the 2 times on power up. And my Home z still is going revers. It goes down initially like it does when Home x and y to give clearance. Then it come up quickly and then slower down as it is looking to trigger the probe but should be moving up... then it comes up quick and goes back down a second time but slower for the second trigger pass. It neve triggers anything cause for starters the probe is still not deployed and also its moving away from the bl touch / nozzel. I am starting to worry I am damaging either my board or z motors.
Here is a fresh batch of config files as they are now.
bed.g config (2).g deployprobe (1).g homeall (2).g homez.g homex.g homey (1).g retractprobe (1).g -
@Shamusseven Sorry, your pics didn't work. Perhaps they were too large?Never mind I guess they are working now.
@Phaedrux can you see them now?
Did you see this comment earlier regarding your Z axis?
This is an Ender 5, so the bed is dropping away from the nozzle as the print progresses, so Z+ should move the bed down. Z- should move the bed up to the nozzle. If it's not doing that, you need to change the motor direction for Z.
; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S0 ; physical drive 3 goes backwards
This is what you have in your config.g and if you have using the Z motor connector for your Z axis, you'd change
M569 P2 S0
toM569 P2 S1
For your deploy and retract macros, please try this, as I was incorrect about the
I1
earlier as @DIY-O-Sphere pointed out.M280 P0 S10 ; deploy BLTouch M280 P0 S90 ; retract BLTouch
If that doesn't help, please try changing
M558 P9 C"^zprobe.in"
to remove the^
If that still doesn't work, check your crimps and wire continuity.
If it does work, you'll need to test functionality with: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
If I hit Z + 5. The bed good down and z-5 it raises, as it should. The only issue there is when I run home z. That is when it appears to run in reverse. Or at least it appears to have an extra movement. Every time I run it, it always ends up further way from the nozzle. The last movement is away from nozzle and stops. So each time I run it, the bed is lower than before.
That's because your homez is setup as if you were using an endstop rather than the probe
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Apr 11 2020 15:51:05 GMT-0500 (Central Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Z-405 F3000 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing G91 ; relative positioning G1 Z5 F100 ; lift Z relative to current position G90 ; absolute positioning
You need to change this part
To match what you have in homeall:
G90 ; absolute positioning G1 X150 Y150 F6000 ; go to first bed probe point and home Z G30
