Cambio elettronica
@Leblond said in Cambio elettronica:
no the printer seen from "front", X stops on the left where the limit switch is positioned, Y stops in front where the limit switch is positioned
Ok, go back to my post above: https://forum.duet3d.com/post/142912
You've managed to change the configuration to force it to work, but it's not working properly.
If the endstops are on the low end it must be M574 X1 Y1.
This also means the homing moves must be negative.
If the motors do not move the right direction at this point you must do these tests to correct the motor rotation:
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
ok guardo
quindi quando si parla di parte bassa si intende il davanti della stampante e parte alta il dietro, giusto?
ho riportato i valori su S1 ma si spostano di pochi cm. e mi da errore, quindi presumo che bisogna far girare i motori al contrario? -
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT+0200 (Ora legale dell’Europa centrale); General preferences
M550 P"X5SA PRO" ; set printer nameM669 K1 ; select CoreXY mode
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S1 ; physical drive 0 goes backwards
M569 P1 S1 ; physical drive 1 goes backwards
M92 X80.00 Y80.00 Z800.00 E420.00 ; set steps per mm
M203 X6000.00 Y6000.00 Z100.00 E1200.00 ; set maximum speeds (mm/min)
M208 X-5 Y0 Z0 S1 ; set axis minima
M208 X352 Y330 Z400 S0 ; set axis maxima; Endstops
M574 X1 S1 P"! xstop" ; configure active-high endstop for low end on X via pin xstop
M574 Y1 S1 P"! ystop" ; configure active-high endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P5 C"! zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
M557 X60:300 Y50:300 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
non funziona
siamo ritornati al punto di partenza quando non andava
Correct.
when we talk about the lower part we mean the front of the printer and the upper part the back, right?
Correct.
M208 X-5 Y0 Z0 S1; minimum axis set
M208 X352 Y330 Z400 S0; set axis maxima
M574 X1 S1 P "! Xstop"; configure active-high endstop for low end on X via pin xstop
M574 Y1 S1 P "! ystop"; configure active-high endstop for low end on Y via pin ystop
M574 Z1 S2; configure Z-probe endstop for low end on ZCorrect.
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 16:46:31 GMT + 0200 (Central European
Summer Time) G91; relative positioning
G1 H2 Z5 F6000; lift Z relative to current position
G1 H1 X-335 Y-335 F1800; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-335; home X axis
G1 H1 Y-335; home Y axis
G1 X5 Y5 F6000; go back a few mm
G1 H1 X-335 F360; move slowly to X axis endstop once more (second pass)
G1 H1 Y-335; then move slowly to Y axis endstop
G90; absolute positioning
G1 X60 Y50 F6000; go to first bed probe point and home Z
G30; home Z by probing the bedCorrect.
Now you must do these tests to find the correct motor settings.
M569 P0 S1; physical drive 0 goes backwards
M569 P1 S1; physical drive 1 goes backwardsChange these to S0.
Then move print head to the center and send G92 X100 Y100.
Then send G91 G1 S2 X10 F3000
If the head moves diagonally in the +X and +Y directions, all is well. If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. If it moves towards +X and -Y, or towards -X and +Y, then either turn the power off and swap the X and Y motor connections, or use M584 in config.g to swap the X and Y motor drivers over.
When you have the X motor moving correctly, test the Y motor by sending from the console: G91 G1 S2 Y10 F3000
If the head moves diagonally in the +X and -Y directions, all is well. If it moves in the -X and +Y directions, change the S parameter in the M569 P1 command to S1.
m569 p0 s0 e m569 p1 s0 cambiati
@Phaedrux said in Cambio elettronica:
G92 X100 Y100 ;questo dice alla stampante che si trova a x100 e y100 giusto?
G91 G1 H2 X10 F3000 : si e' spostata in diagonale verso dx e rear -
Correct
Correct.
Now move on to the next move G91 G1 S2 Y10 F3000
G91 G1 H2 Y10 F3000 ok si e' spostata a dx e front
Ok, so that means your settings should be good.
If you send G91 G1 X10 it should move right
If you send G91 G1 Y10 it should move to the backIf you use the homeall I quoted above, you should now be able to home correctly.
G91 G1 X10 ; va a dx - ok
G91 G1 Y10 ; va indietro - ok
Faccio L'homing ma invece di andare verso i finecorsa va dalla parte opposta -
; homeall.g
G30; home Z by probing the bedDoes your homeall match this?
te lo mando
; homeall.g
G91 ; relative positioning
G1 H1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-335 ; home X axis
G1 H1 Y-335 ; home Y axis
G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-335 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X60 Y50 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
si sposta verso il dietro e a dx
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT + 0200 (Central European
Summer Time) G91; relative positioningI think the problem may be here. The G91 must be on a new line.
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT + 0200 (Central European Summer Time)
G91; relative positioning -
scusami errore mio M574 X1 S1 P"!xstop" avevo tolto "!"
Adesso funziona grazie della pazienza che mi hai dimotrato fratello
