Cambio elettronica
@droftarts grazie
@droftarts said in Cambio elettronica:
M564 S0 H0
ho lanciato il comando M564 S0 H0, poi G1 X50 F200 non funziona, quindi ho provato a mandare l'asse x in home, ma mi si e' alzato l'asse Z, forse qualcosina non quadra -
@Leblond It sounds like you have connected the stepper motors to the wrong pins! See the wiring diagram here for the motor connections: https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
If your wiring is correct, post your config.g file. Also send M115 and post the response.
0:/sys/config.g.bak
; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 31 2020 13:40:08 GMT+0200 (Ora legale dell’Europa centrale); General preferences
M550 P"X5SA PRO" ; set printer nameM667 S1 ; select CoreXY mode
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
M208 X330 Y330 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
M557 X60:300 Y50:300 S20 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@Leblond said in Cambio elettronica:
M584 X0 Y1 Z2 E3
That looks okay. Note that the order of the driver pins on the board, from left to right, is E1, E0, X, Y, Z.
M550 P"X5SA PRO" ; set printer name;M667 S1 ; select CoreXY mode
M669 K1
M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
sicuramente e' tutto sbagliato ma l'ho fatto con il configuratore reprap
l'unico problema elettrico che ho riscontrato e' il colore dei fili
2b rosso
2a blu
1a verde
1b neroma la connessione dei fili dei motori sono invertiti le fasi 1a e 1b
che sia quello? -
cioe' i cavi dei motori che dovrebbero essere 2b-R 2a-B 1a-V 1b-N sui fili 1a e 1b sono invertiti
G28
Error: Z probe already triggered at start of probing move -
Ragazzi ho realmente bisogno di voi, non ce ne salto fuori, mi continua a dare come errore Z probe already triggered at start of probing move
Non so come fargli cambiare stato
smanettando qualcosa e' cambiato non so il perche' ma nel file home x e y invece di sondare a 0 sondava a 335
adesso l'errore e' cambiato dicendomi G0/G1: insufficient axes homed -
@Phaedrux ; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 31 2020 22:19:23 GMT+0200 (Ora legale dell’Europa centrale)
G91 ; relative positioning
G1 H2 Z10 F3000 ; lift Z relative to current position
G1 H1 X0 Y0 F500 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X0 ; home X axis
G1 H1 Y0 ; home Y axis
G1 X-5 Y-5 F500 ; go back a few mm
G1 H1 X0 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y0 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X60 Y50 F500 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z10 F50 ; lift Z relative to current position
;G90 ; absolute positioning -
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 31 2020 22:19:24 GMT+0200 (Ora legale dell’Europa centrale)
G1 H2 Z-9999 F3000 ; lift Z relative to current position
G1 X60 Y50 F3000 ; go to first probe point
a sembra tutto ok, ma posso anche sbagliarmi
ok ho fatto esperimento, ho mandato gli assi in home mettendo una parte mettalica sotto il sensore ma questo pur segnando 0 partendo da 1000 non si ferma
