Duet3D System won't turn on now
@Danal said in Duet3D System won't turn on now:
. It will actually be apt-get so,
apt-get is the old syntax, but still works. might as well get with the times
Wonderful guys!
I now have:
duetcontrolserver 1.2.5.0
duetruntime 1.2.5.0
duetsd 1.0.5
duetsoftwareframework 1.2.5.0
duettools 1.2.5.0
duetwebcontrol 2.0.7-1
duetwebserver 1.2.3.1BTW, how do you capture part of he PuTTy screen as Danal shows in his "This is what I get: " screen shot above?
Thanks again,
Jim -
@Jim46 said in Duet3D System won't turn on now:
just drag and select with the mouse; it copies to the clipboard automatiacally.
then paste and use the code formatting button (in the forum's editor when replying)
Yep, I was able to highlight an area I wanted to copy, the following steps didn't work.
What does the S with line mean? Then how does the </> work? I get newline error msgs.
Then what does the chain link symbol mean? I think I need a beer! -
S with line =
strike through textHighlight the text (with mouse) and click it.</> really just types three backticks for you, on two different lines, and places the cursor between those two lines so you can paste. You can type the three backticks yourself if you wish.
OK, we've gotten past the flash once a second, and we've got you on current releases.
Are you able to connect to DWC?
If not, can you please verify IP address, as shown way above?
Thanks for the comments and advice.
Presently, RPi4 is connected to the SunFounder 10.1 touch screen. The Pi is connected to the Duet3d. 12v Power comes to the SF screen. It connects to the Pi. The Pi is ribbon cable connected to the Duet3d. There is no SD card in the Duet3d. The Pi has its card installed.
The Duet has UBS power 5v coming in from a UBS plug on a power-strip. I've run it with no UBS power going to the Duet3d or having UBS power going into the Duet3d.
I've verified the IP address on my router. It shows RPI4 and the IP number I'm using.
I'm using a new Firefox download.
I load in the IP address in the search bar and the Duet Web Control 2 comes up and quickly says Failed to Connect 192.168.1.xxx, DCS unavailable.I've also done this w/o the SF screen being attached. Same result. I've also opened up the browser using Pi on the SF screen and input the IP. The Duet Web Control comes up and gives the same result.
Above dc42 mentioned differing version of RRF and DCS being an issue. With recent results on PuTTy is that still an issue? I certainly don't understand why progress is hampered.
Any miracles available? -
I seems to have UBS (Union Bank System) on the brain rather than the USB.... duh!
DCS unavailable.
what does
service duetcontrolserver status
say from the ssh? -
You are on correct releases. No issues there.
Just a tiny modification to what bearer asked; please show us two commands:
sudo service duetcontrolserver restart sudo service duetcontrolserver status ā duetcontrolserver.service - Duet Control Server Loaded: loaded (/lib/systemd/system/duetcontrolserver.service; enabled; vendor preset: enabled) Active: active (running) since Sun 2020-03-29 18:07:24 CDT; 6s ago Main PID: 17210 (DuetControlServ) Tasks: 19 (limit: 4915) Memory: 17.9M CGroup: /system.slice/duetcontrolserver.service āā17210 /opt/dsf/bin/DuetControlServer Mar 29 18:07:24 duet3 systemd[1]: Started Duet Control Server. Mar 29 18:07:25 duet3 DuetControlServer[17210]: Duet Control Server v1.2.5.0 Mar 29 18:07:25 duet3 DuetControlServer[17210]: Written by Christian Hammacher for Duet3D Mar 29 18:07:25 duet3 DuetControlServer[17210]: Licensed under the terms of the GNU Public License Version 3 Mar 29 18:07:25 duet3 DuetControlServer[17210]: [info] Settings loaded Mar 29 18:07:25 duet3 DuetControlServer[17210]: [info] Environment initialized Mar 29 18:07:25 duet3 DuetControlServer[17210]: [info] Connection to Duet established Mar 29 18:07:25 duet3 DuetControlServer[17210]: [info] IPC socket created at /var/run/dsf/dcs.sock
Hi All ,
Here is what I get processing the two commands requested.
I'm still not getting the method you sue to capture the screen. So, here's another pic. I hope you can read it. On a side note, you all are world class with this program. I'd like to catch up a little. Where would you suggest I go to learn this rather quickly?
Cheers,
Jim -
Doesn't really say why its not starting. But the only thing that should keep it from starting is not finding the Duet3. Maybe its time for a picture of how its connected?
![0_1585597426269_IMG_5078.JPG](Uploading 100%) ![0_1585597463081_IMG_5079.JPG](Uploading 100%)
Here are two shots of my setup. The Duet is powered by the USB from a power strip. The SunFounder is powered by its plug in the same power strip. The Pi4 is powered by a connection to the SF board.
The latest message from the Duet Web Control 2 is "Failed to connect to IP, Network error".
Also, this Duet messaging system is not showing the Preview. WError?
Jim -
Okay here are the shots. I hope they help.
J -
By any chance is this indicative of a bad Duet board?
We need to know whether the Duet is running RRF. With the Duet connected via USB to a PC by a suitable cable (one that connects the data pins, not just power), does the USB port show up on the PC? If so, does it respond to sending M115?
Hi DC. I'm not sure of he answer to your question. This is the cable connected from power strip to the Duet. Perhaps this pic will help?
Thanks,
j -
Plug it back in the Pi and check if you have a /dev/ttyACM0 device. Connect to it with your serial terminal of choice and send it
M115
to see if the Duet board responds.if the above didn't make sense, just copy and paste the commands below and share the results
lsusb stty -F /dev/ttyACM0 57600 raw -echo && { cat /dev/ttyACM0 & PID=$! echo "M115" > /dev/ttyACM0 sleep 0.5s ; kill $PID ; wait $PID }
(edit: for those who finds the thread later - the above assumes micro usb of Duet is connected to the Pi)
So sorry Bearer. Don't know how to do the ACM0 M115 line.
So I launched PuTTy and tried to execute the 7 lines of code in the black panel. Nothing was understood. I imagine I'm missing a basic understanding on how to start this. What should I do? -
Not sure what to tell you man, I specifically tried this with a raspberry pi and a duet board to make it as simple as copy and paste.
video didn't capture right clicking the selected text and choosing copy, nor right clicking once back in the ssh terminal to paste the text, but it works with the default setup (putty behaves in the same way, but the chrome ssh client was just easier to record as it was all in a single window)
that also tells me nothing about what went wrong.
edit; copy/pasted the ssh session for those who can't view the video (with a slight change to commands)
pi@raspberrypi:~ $ lsusb Bus 001 Device 005: ID 1d50:60ed OpenMoko, Inc. Bus 001 Device 004: ID 0424:7800 Standard Microsystems Corp. Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub pi@raspberrypi:~ $ stty -F /dev/ttyACM0 57600 raw -echo && { > cat /dev/ttyACM0 & PID=$! > echo "M115" > /dev/ttyACM0 && > sleep 0.5s && kill $PID ; wait $PID > } [2] 829 FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-02-09b1 [2]+ Terminated cat /dev/ttyACM0 pi@raspberrypi:~ $
