[SOLVED] X/Y endstops not stopping motors, carriage grinds motor
Usually stack over flow or under flow mean there is a compiling error, to my knowledge.
@RyanP Please check how you have connected the X and Y endstops. It sounds like they are reversed, or one is connected to Z endstop.
Can you send M115 and verify what firmware version you're using?
Endstops are only active during homing moves (G1 H1).
Moves with G1 H2 should allow movement without using M564 H0, so this leads me to believe you are using an older firmware version that doesn't understand G1 H1/G1 H2. It used to be G1 S1/G1 S2.
@Phaedrux said in X/Y endstops not stopping motors, carriage grinds motor:
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.01beta1(RTOS) ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2018-06-23b1 -
@RyanP said in X/Y endstops not stopping motors, carriage grinds motor:
2.01beta1
Please update to 2.05 and you'll find your problem is resolved.
Your homing files are using H1/H2 which is not supported syntax in your very old version.
@Phaedrux Well spotted! We should get the forum software to enforce people put the M115 response in the first post of a thread...
2.01beta1
Perfect. Thank you very much. I thought simply swapping boards would be ok. Lesson Learned.
2.01beta1
I spoke too quickly. I grabbed another SD card and did the complete RepRap config tool again. Created a brand new SD card for this new board. Plopped it in. Again, same problem.
So I have done an SD card from scratch. And my M115 looks like this:
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.01beta1(RTOS) ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2018-06-23b1Im pretty sure that is the same as before.
Ryan,
You are still running 2.01beta, you need to update as @Phaedrux suggested
Get the files from here and upload to your Duet.
https://github.com/dc42/RepRapFirmware/releases/tag/2.05Regards,
Paul. -
You'll need to download the 2.05 zip file from PaulHews link and upload it tot eh system folder using the DWC. It should prompt you to update the firmware.
The firmware is flashed to the board itself, not the SD card.
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
Thanks for confirming that. Will do that now.
Fixed. Thought I did that yesterday and was perplexed by the same firmware being reported. I greatly appreciate you help. Back to printing.
I just upgraded to 2.05.1 after having the same issue. Though, before i flashed to 2.05.1 the motors were completely silent, now they make a noise.
@Justin Please start a new thread.
