[SOLVED] X/Y endstops not stopping motors, carriage grinds motor
Update, hoping this helps somebody solve this problem.
The the M564 S0 in place I can manually move around the motors. So I can move the X and Y carriages to the endstops, make the click, and then send G92 X0 and G92 Y0.
This makes the "Home X" and "Home Y" on the web interface change from orange to blue. And the motors will stop when they get to 0.00 now.
But, when I hit "Home All", they continue to want to plow right through the endstops.
So while M119 is registering the endstops as properly triggered, they are not instructing the motors to stop. Basically, they are not "zeroing".
Is it possible I need to reset the board?
Please post your latest config.g
G92 resets its home position, I only use G92 when I am resetting my Z axis after levelling it.
Take the G92 out and reboot the printer before any damage is done!
@Phaedrux created some guides for the Ender3 which are extremely helpful, I use them even with a CoreXY printer.
Have you seen them?You can see the endstops triggering in DWC, under 'Machine-Specific' on the left hand side.
When you click Machine specific or the RHS there should be a box labelled 'Endstops'
If you manually press the endstop switches they should change their state.HTH
Paul.
It kind of sounds like your coordinate system is a bit out of whack.
Have a look through this post and verify that you have a right hand coordinate system with 0,0 in the front left corner. +X going to the right and +Y going to the back and htat your endstop locations are reflected correctly in M574 and your homing moves are also correct direction.
https://forum.duet3d.com/topic/12676/mirrored-x-axis/9?_=1584807834877
@PaulHew said in X/Y endstops not stopping motors, carriage grinds motor:
G92 resets its home position, I only use G92 when I am resetting my Z axis after levelling it..
Paul.
Hi Paul,
Couple of things. I'm only using the G92 temporarily to create the software endstop. I wanted to see if the machine would stop at 0.00, which it does. So onto the more perplexing thing.
Since I sent M564 S0 to allow me to move the axis before homing, I can move the axis to the 0.00 point for each axis. Whether I manually trigger them, or move the axis carriages into them, they respond correctly in 'Machine Specific'. But when it is triggered, it is not telling the steppers/motors to stop.
But it did it perfectly the previous D2M board that I had been using for 2 months.
My CR10S is working excellently on a Duet 2 Wifi board. And my troubleshooting/researching skills are pretty solid, but this one has me baffled.
Config.g
; Configuration file for Duet Maestro (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Feb 18 2020 18:08:43 GMT-0500 (Eastern Standard Time); General preferences
M550 P"Ender5Pro - 3DimensionGames" ; set printer name
M564 H0 ;allow movement without homing; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X80.15 Y79.04 Z800 E410 ; set steps per mm
M566 X900 Y900 Z30 E300 ; set jerk (mm/min)
M203 X7200 Y7200 Z600 E6000 ; set maximum speeds (mm/min)
M201 X1200.00 Y1200.00 Z240.00 E5000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X235 Y235 Z260 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M558 P9 H2 F90 T24000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X41 Y24 Z0.87 ; set Z probe trigger value, offset and trigger height
M557 X45:225 Y30:210 S45 ; define mesh grid; Heaters
M305 P0 T100000 B3950 R2200 ; set thermistor + ADC parameters for heater 0
M143 H0 S150 ; set temperature limit for heater 0 to 150C
M305 P1 T100000 B3950 R2200 ; set thermistor + ADC parameters for heater 1
M143 H1 S275 ; set temperature limit for heater 1 to 275C; Fans
M106 P2 S1 I0 F500 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M501
M572 D0 S0.18; set K-factor -
This post is deleted! -
@Phaedrux said in X/Y endstops not stopping motors, carriage grinds motor:
The coordinate system is fine. It was working fine on the previous maestro board.
Question, when an endstop is triggered, what part of the HW/SW/FW is actually telling the steppers to stop sending current to the motors?
I can hold the endstop closed, and still move the motors around. The system is simply disregarding the endstop all together.
Please post you Homex.g and homey.g, lets check them!
Also, if you are going to paste text from your config, use the </> button above, where you can set bold and italics. (I only learnt this one the other day!!)
P.
P.
homex.g
; homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Feb 18 2020 18:08:46 GMT-0500 (Eastern Standard Time)
G91 ; relative positioning
G1 H2 Z5 F24000 ; lift Z relative to current position
G1 H1 X-240 F8000 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X20 F12000 ; go back a few mm
G1 H1 X-240 F1000 ; move slowly to X axis endstop once more (second pass)
G90 ; absolute positioning
homey.g
; homey.g
; called to home the Y axis
; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Feb 14 2020 22:01:04 GMT-0500 (Eastern Standard Time)
G1 H2 Z5 F12000 ; lift Z relative to current position
G1 H1 Y-240 F8000 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y20 F12000 ; go back a few mm
G1 H1 Y-240 F1000 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning -
It all seems good, and was working before.
@RyanP said in X/Y endstops not stopping motors, carriage grinds motor:
Try removing this line.
P.
If I remove that, and it wasn't there before this problem, the printer will simply not move.
So I uncommented that line.
Hitting Home All or any individual axis home button gives this error:
G28
Error: G0/G1: insufficient axes homedAsking the printer to move in any direction using the buttons next to the home buttons result in this error:
M120
G91
G1 Z25 F6000
M121
Error: Pop(): stack underflow! -
Usually stack over flow or under flow mean there is a compiling error, to my knowledge.
@RyanP Please check how you have connected the X and Y endstops. It sounds like they are reversed, or one is connected to Z endstop.
Can you send M115 and verify what firmware version you're using?
Endstops are only active during homing moves (G1 H1).
Moves with G1 H2 should allow movement without using M564 H0, so this leads me to believe you are using an older firmware version that doesn't understand G1 H1/G1 H2. It used to be G1 S1/G1 S2.
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.01beta1(RTOS) ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2018-06-23b1 -
2.01beta1
Please update to 2.05 and you'll find your problem is resolved.
Your homing files are using H1/H2 which is not supported syntax in your very old version.
@Phaedrux Well spotted! We should get the forum software to enforce people put the M115 response in the first post of a thread...
2.01beta1
Perfect. Thank you very much. I thought simply swapping boards would be ok. Lesson Learned.
2.01beta1
I spoke too quickly. I grabbed another SD card and did the complete RepRap config tool again. Created a brand new SD card for this new board. Plopped it in. Again, same problem.
So I have done an SD card from scratch. And my M115 looks like this:
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.01beta1(RTOS) ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2018-06-23b1Im pretty sure that is the same as before.
