Is there a basic guide to set the duet up as a CNC
@Asdasd1234 said in Is there a basic guide to set the duet up as a CNC:
Ok so am I right in saying :
- I have a gcode file (just a re-named .nc file from fusion 360)
- I home my machine using g28.
- I jog the machine to the start of the file gcode
- Use G10 L20 P2 X0 Y0 Z0 To set the co-ords for the start of the file.
- then run the file?
How do I ensure the file runs using the work co-ords and not the machine co-ords? Do I need to specify it at the start of the file?
You are basically correct, here is a slight rephrasing of a couple of lines, just for clarity.
- I have a gcode file (just a re-named .nc file from fusion 360) Correct, upload that file via the Web interface
- I home my machine using g28. Correct
start of the file gcodeto the tip of the cutter just touching the origin of the stock. Normally in the 'lower left' corner, and just touching top-of-stock in Z. - Use G10 L20 P2 X0 Y0 Z0 To set the co-ords for the
start of the file.the second work-coordinate-system (G55) to match the physical object I want to cut - then run the file? Issue a G55, then, Yes, in the Jobs tab, click then file, then OK
G28 home the machine
Jog machine to start of file.
Run macro that does:
-G10 L20 P2 X0 Y0 Z0
-G55
Then run the file?Yes
@Danal
Thats great, I'll try that now. Thanks a bunch for the help people. Its much appreciated -
No problem.
This does assume you've set Z0 to top of stock in Fusion. This is a fairly normal CNC practice.
@Danal
I'm pretty sure I have, but will double check -
Ah, I might have an issue.
F360, when set to grbl only lists out the co-ordinates and doesn't do a G1/0 before them like:
G1 Z1 F500 Z-1.999 Y26.033 Z-2 F1200 Y26.034 X28.967 Y26.035 X28.595 Y26.047 X28.194 Y26.057 X27.792 Y26.067
Will this still work?
No. Duet doesn't support "sticky" G1 or G0. You will need to select a different post processor, or modify that one.
I use Mach3 post. Which isn't perfect, but it does put G1 on each line.
i found a post processor online for duet. I need to manually delete out the G54 at the start, but my test pen-plot has come out perfect. Thanks a bunch!
you can edit the .cps file and change the line that says (line 28 in the grbl if thats what you used)
extension = "nc";
to say
extension = "gcode";
to not have to do the renaming.@Asdasd1234 said in Is there a basic guide to set the duet up as a CNC:
try putting a "2" in WCS offset here if you wanted G55 instead.
Setup -> Post process tab:
(edit: or you could edit the file and change 1 to 2 in line 353 to make it permament and not have to set it each time.)
((or search forvar workOffset = currentSection.workOffset;
and changeworkOffset = 1;
toworkOffset = 2;
a few lines below if your post is different from the grbl))
(((or if you just wanted to get rid of the whole G54 thing try changeing the Safe retracts parameter in the post to ClearanceHeight
@Danal said in Is there a basic guide to set the duet up as a CNC:
Yes it does, when in CNC mode and using recent firmware versions (2.05 or 3.x).
@bearer said in Is there a basic guide to set the duet up as a CNC:
extension = "nc";
to say
to not have to do the renaming.You don't have to rename anyway. DWC and RRF accept .nc files.
-G55Alternatively, use P1 in the G10 command instead of P2, then you don't need the G55.
@dc42 said in Is there a basic guide to set the duet up as a CNC:
Ah... I tried it, but not in CNC mode... grasshopper learns from master once again.
This is true... but... a lot of people like to leave G54 matching machine, because there the controller is always in some Work Coordinate System, and it just makes more sense for the human to have G54 match the physical layout of the device, G55 match the first fixture, G56 the second fixture and so forth.
Again, there is no "right or wrong" here... and some people do it a completely different way... the most common practice I've seen is leaving G54 alone (or, technically, G54 has a 0,0,0 offset to G53).
