Continue blocking during printing.
Power up your printer, then send the M350 command. It will report what microstepping is selected.
@dc42 I just did the M350 command. Oddly enough, it gives me this result
Microstepping - x:256, y:256, z:256, e:16:16
In my configuration posted above I clearly put 16 interpolated microsteps at 256, excluding extruder that I will now also put at 256 interpolation,
check your config-override.g
@AndreS
; config-override.g file generated in response to M500 at 2020-03-10 10:27
; Delta parameters
M665 L360.270:360.270:360.270 R185.353 H364.129 B150.0 X0.229 Y0.060 Z0.000
M666 X1.793 Y-1.094 Z-0.699 A0.00 B0.00
; Heater model parameters
M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00 -
Try sending
M350 X16 Y16 Z16 E16 I1
Once the machine has started up. Then resend M350 and make sure it reports back 16 microsteps for each axis.
If it does, it means that a file somewhere still has incorrect values for M350, causing the wrong values to be loaded on start up
@jay_s_uk
I just tried, I always 256 microsteps, besides the config are in other places the parameters of microsteps? -
I found inside config.g.bak all the steps at 256 microsteps, I change them to 16?
config.g.bak doesn't get loaded at system start up
@Fedekossel1 said in Continue blocking during printing.:
@jay_s_uk
I just tried, I always 256 microsteps, besides the config are in other places the parameters of microsteps?That's the problem! Change XYZ to x16 microstepping with interpolation. If your E steps/mm is 400 or above, set that to x16 with interpolation too. If it is less than 400, set E microstepping to x64.
I fixed, it's normal that it doesn't tell me giving the command M350 "example" X:16 (on),
From config I put
M350 X16 Y16 Z16 E16 I1Typing the M350 command gives me this result
M350
Microstepping - X:16, Y:16, Z:16, E:16:16``` -
I just set all the axes correctly to 16 microsteps interpolated to 256, with the same gcode that froze, now goes without stopping. I keep you updated these days if I get problems or blocks during printing. At the moment I thank everyone!
From config I put
M350
Microstepping - X:16, Y:16, Z:16, E:16:16```Check that you have entered the I1 parameter correctly. That's letter i followed by digit 1.
