Possible RRF3 FW bug?
I've been investigating the object model and found that the following script resets my Duet.
Board: Duet WiFi 1.02 or later + DueX5
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.01-RC3 (2020-02-29b4)
Duet WiFi Server Version: 1.23(also tested on Duet 2 3.01 RC1 and RC2)
echo "fans[0].name :",fans[0].name echo "fans[1].name :",fans[1].name echo "fans[2].name :",fans[2].name echo "fans[3].name :",fans[3].name
M122 report is
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC3 running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DGM-95BLL-N6PSS-6JKD2-3SJ6M-10UMJ Used output buffers: 3 of 24 (14 max) === RTOS === Static ram: 27916 Dynamic ram: 93976 of which 44 recycled Exception stack ram used: 272 Never used ram: 8864 Tasks: NETWORK(ready,732) HEAT(blocked,1240) DUEX(suspended,136) MAIN(running,1924) IDLE(ready,76) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:00:36 ago, cause: software Last software reset at 2020-02-29 22:51, reason: Hard fault, spinning module GCodes, available RAM 8536 bytes (slot 3) Software reset code 0x0063 HFSR 0x40000000 CFSR 0x00000001 ICSR 0x0041f803 BFAR 0xe000ed38 SP 0x20004f04 Task 0x4e49414d Stack: 004043f7 b2c96804 000f0000 00000000 a5a5a5a5 200051b8 0042cad9 00000001 20001408 00000001 00000000 Error status: 0 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 3.3ms, max retries 0 MCU temperature: min 41.1, current 42.5, max 43.1 Supply voltage: min 23.9, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max not available Driver 1: standstill, SG min/max not available Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Driver 5: standstill, SG min/max not available Driver 6: standstill, SG min/max not available Driver 7: standstill, SG min/max not available Driver 8: standstill, SG min/max not available Driver 9: standstill, SG min/max not available Date/time: 2020-02-29 22:52:02 Cache data hit count 64014950 Slowest loop: 46.43ms; fastest: 0.12ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 168, MaxWait: 546ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 trigger is idle in state(s) 0 queue is idle in state(s) 0 daemon is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 81.29ms; fastest: 0.00ms Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address 2c:3a:e8:0b:09:f7 WiFi Vcc 3.41, reset reason Turned on by main processor WiFi flash size 4194304, free heap 24080 WiFi IP address 192.168.0.26 WiFi signal strength -51dBm, reconnections 0, sleep mode modem Socket states: 4 0 0 0 0 0 0 0
M409 K"fans" is
{"key":"fans","flags":"","result":[{"actualValue":0,"blip":0.10,"max":1.00,"min":0.10,"name":"","requestedValue":0,"rpm":-1,"thermostatic":{"control":false}},{"actualValue":0,"blip":0.10,"max":1.00,"min":0.10,"name":"","requestedValue":0,"rpm":-1,"thermostatic":{"control":false}},{"actualValue":0,"blip":0.10,"max":1.00,"min":0.10,"name":"Part","requestedValue":0,"rpm":-1,"thermostatic":{"control":false}},null,null,null,{"actualValue":0,"blip":0.10,"max":1.00,"min":0.10,"name":"Hotend","requestedValue":1.00,"rpm":-1,"thermostatic":{"control":true,"heaters":[1],"highTemperature":45.0,"lowTemperature":45.0}},{"actualValue":0.38,"blip":0.10,"max":1.00,"min":0.10,"name":"Elec.Cab.1","requestedValue":1.00,"rpm":-1,"thermostatic":{"control":true,"heaters":[10],"highTemperature":55.0,"lowTemperature":35.0}},{"actualValue":0.38,"blip":0.10,"max":1.00,"min":0.10,"name":"Elec.Cab.2","requestedValue":1.00,"rpm":-1,"thermostatic":{"control":true,"heaters":[10],"highTemperature":55.0,"lowTemperature":35.0}}]}
I don't know if this is useful additional information but I asked someone with Duet Ethernet 1.02 or later + DueX5 and RepRapFirmware for Duet 2 WiFi/Ethernet 3.01-RC1 (2020-02-08b3) to run
echo "fans[0].name :",fans[0].name echo "fans[1].name :",fans[1].name echo "fans[2].name :",fans[2].name echo "fans[3].name :",fans[3].name echo "fans[4].name :",fans[4].name echo "fans[5].name :",fans[5].name echo "fans[6].name :",fans[6].name echo "fans[7].name :",fans[7].name echo "fans[8].name :",fans[8].name
They reported that they got "Error: in file macro, line 7 column 23: array index out of bounds"
I confirm this is a bug. It occurs when there are gaps in the fan numbering. I will fix it in 3.01 release. Meanwhile I suggest you use this instead:
if fans[0] != null echo "fans[0].name :",fans[0].name if fans[1] != null echo "fans[1].name :",fans[1].name if fans[2] != null echo "fans[2].name :",fans[2].name if fans[3] != null echo "fans[3].name :",fans[3].name
or why not:
while iterations < #fans if fans[iterations] == null echo "Fan",iterations,"not configured" else echo "Fan",iterations,"name:",fans[iterations].name echo "That''s all"
While writing that I found another bug: you need another command after the end of a while block before end of file, otherwise when end of file is reached the while block is terminated. I'll fix that too in 3.01 release.
Great news. Thanks dc42!
