New firmware 3.01-RC2 available
@dc42 Is it possible to have the Duet "Emergency Stop" when a Stack overflow occurs?
@TurtlePrint said in New firmware 3.01-RC2 available:
I can quite easily make it abandon the current print job.
@dc42 said in New firmware 3.01-RC2 available:
There is an additional parameter to the rr_upload command that specifies the date/time to use for the time stamp.
ah, didn't know that
What was the latest version of RRF for which the time stamp was set when you uploaded files using curl?
The update to the RRF and script for s3d came roughly at the same time so I started using CURL when I updated to RC2
Note, you need to have connected to the Duet with DWC before you do
That's the missing link! Thanks, that solved the problem
Apologies for the false alarm.Will modify the script to send proper time value, thanks for example.
Is there a way to tell DWC to refresh file list using curl?
@arhi said in New firmware 3.01-RC2 available:
Not AFAIK, but @chrishamm might know otherwise.
Hey - will state.previoustool be persistent through power cycle/M999?
It would be nice if there could be a condition check on homing to make sure that the previous tool is re-docked before attempting a home, to prevent damage to tool (especially from inattentive tinkerers) -
@Luke-sLaboratory said in New firmware 3.01-RC2 available:
It would be nice if there could be a condition check on homing to make sure that the previous tool is re-docked before attempting a home, to prevent damage to tool (especially from inattentive tinkerers)The only things that persist across a restart are data stored in config-override.g when you run M500, and the software reset data.
For tool changers I suggest using microswitches to detect when tools are docked, or a microswitch to detect when a tool is loaded.
@dc42 Talking about tool changes... is it possible also to have a nexttool object? That would make it possible to already preheat the next tool to be used.
@TC said in New firmware 3.01-RC2 available:
A facility to read the GCode stream ahead so that tools can be preheated and filament mixes changed in advanced is planned for Duet 3. There probably isn't enough RAM to fit it in Duet 2.
I have Duet 2 Wifi and i have same problem with fan rpm showing random number's. So i will try this update to see is will be same or it will dissape. Thanks @dc42.
A few questions:
Do we still have a line length limit? Object model fetches such as 'heat.heaters[tools[state.currentTool].heaters[0]].current' burn through characters quite quickly.
How are line numbers counted when I get a syntax error? The line number given by RRF does not match the error location. Should it be file-linenumber, or are things like empty lines and comment lines skipped?
About the maximum stack depth: how deep is it? It is tempting to split code to separate macros, just like you would normally do with functions. This does increase nesting depth though.
I do not really want to bother you guys with this yet since I have to carefully check the hotend heating before complaining, but I see 'maximum excursion' heater faults when I do not expect them, such as soon after programming a lower temperature for an active heater. Did anything change in RC2 regarding heater fault detection?
@DaBit said in New firmware 3.01-RC2 available:
Yes, 160 characters, not counting leading spaces/tabs.
It should be line number within the file, with 1 being the first line. If you think it doesn't match, please submit a simple example that reproduces the issue. The column number (if given) is generally the number of the character after the item that caused the problem.
5 at present, but it will be increased to 7 in the next release or RC.
Not intentionally. Again, if you can reproduce a problem, please post a demo file.
With heater 1/tool 0 active and heater 2/tool 1 standby, executing a 'G10 P1 S250 R200' at the console triggers an 'Error: Heating fault on heater 2, temperature excursion exceeded 15.0°C' after a few seconds.
'M109 T1 S200' works. 'G10 P0 S250 R200' works. Machine homed or not does not change the behaviour.
If I execute a T1 so T0 is put in standby and T1 is made active, the behaviour reverses. 'G10 P0 S250 R200' triggers an error, 'G10 P1 S250 R200' works as expected.
For this test I made sure there were no active M570 commands in the config.
Heaters/tools sections of the config.g:
; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 Q5 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S140 ; set temperature limit for heater 0 to 140C M307 H0 A486.1 C2320.7 D16.5 S1.00 V24.0 B0 ; PID-parameters for heated bed M308 S1 P"spi.cs1" Y"rtd-max31865" M950 H1 C"e0heat" T1 Q50 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S290 ; set temperature limit for heater 1 to 290C M307 H1 A675.5 C232.3 D2.8 S1.00 V23.7 B0 M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp M950 H2 C"e1heat" T2 Q50 ; create nozzle heater output on e1heat and map it to sensor 2 M143 H2 S290 ; set temperature limit for heater 2 to 290C M307 H2 A650.8 C253.7 D3.6 S1.00 V23.8 B0 ; PID parameters for heater 1 ; Auxiliary temp sensors M308 S3 P"mcu-temp" Y"mcu-temp" A"mcu-temp" ; MCU temp M308 S4 P"e0temp" Y"thermistor" A"Chamber" T100000 B4725 C7.06e-8 ; configure sensor 3 (chamber temp) as thermistor on pin e0temp ; Tools M563 P0 S"Extruder 0" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"Extruder 1" D1 H2 F0 ; define tool 1 G10 P1 X19.88 Y0.1 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C M104 S0 T0 ; make sure the heater is not 'off' M104 S0 T1 ; make sure the heater is not 'off'
If I execute a T1 so T0 is put in standby and T1 is made active, the behaviour reverses. 'G10 P0 S250 R200' triggers an error, 'G10 P1 S250 R200' works as expected.I confirm this was an unintended change in 3.01-RC2. Please can you check that the new binary at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0 corrects it. This binary also has the maximum stack depth increased to 7.
I can confirm that the issue is resolved.
Thanks for the exceptionally quick response, once again!I will check the error line numbers later, with this firmware.
I haven't changed the line numbering in this build, so I expect the issue is unchanged. Please supply a test file to reproduce it.
Is it actually possible to define more than one probe?
I tried M558 K1 for G38.x and M585 but it always responds only for my Zprobe
@smoki3 said in New firmware 3.01-RC2 available:
Currently it's possible to define more than one probe but not to switch between them.
@dc42 I don't understand?
; Z-Probe M558 K0 P5 C"^!zprobe.in" H3 F180 T25000 ; Z probe connected to Z endstop input G31 K0 X0 Y0 Z0.17 P500 ; Set Z probe offset + naher ran - weiter weg ; Tool Probe M558 K1 P5 C"!e0stop" H5 F120 T3000 ; Tool probe connected to Z endstop input G31 K1 X0 Y0 Z0 P500 ; Set Z probe offset + naher ran - weiter weg
I defined this one. If I report the probe status with G31 K0 or K1 it always only responds for K0. If I try to use it K1 in G38.2 P1 or in M585 P1 it only react when K0 is trigged and not for K1
I see the problem, which is that there is only one Z probe input filter. So only one Z probe can be type 1,2,3 or 5. Defining two type 8 Z probes works for me. I will add a note to the M558 description.
Running 3.01-RC2 on the expansion board, for me at least, results in none of the motor drivers working.
I have had to roll back to 3.0-RC2 to get them to work and to be able to print.
