Rat rig v-core pro COREXYU
thank you so much
yes actually I hadn't seen her,
I see it has 4 motor 4 runs gt3,
its not going to be easier for me to transform my rat rig into MarkForged kinematics, with 3 motor and 3 belt its just makes me modify one motor and one belt,
I’m not, but since the configuration of the duet will not be easy for me, I will not launch into an impossible project,merci beauqou
oui effectivement je navais pas vue sa,
je voie il a bien 4 moteur 4 couroie gt3 ,
sa serai pas pas plus facile pour moi de transformer mon rat rig en cinématique MarkForged , avec 3 moteur et 3 couroi sa me ferai modifier , pour rajouter un moteur et une couroi ,
je cest pas , mais comme le parametrage du duo me serat pas facile que je me lance pas dans un prjet impossible , -
@neetspeed said in Rat rig v-core pro COREXYU:
With the help you receive here the configuration won't be too hard. If you build it, the configuration is the easy part.
ok that's really nice,
I start, I will choose the 3d wifi duet, and launch my corexy and add the additional axis,
I have a person who sells a lot of original new part with invoice, follows an abandonment of project (card duet 2 3d, screen 7 inch, etc etc) contains 5 engines 0.9 degree c well, or I stay on engines 1.8 degreeNema17 Stepper Motor 17HM5417 0.9 degree
thank you
ok c vraiment gentil ,
je me lance , je vais choisir la duet 3d wifi ,et lancer mon corexy et rajouter l'axe suplementaire ,
jai une personne qui vend un lots de piece neuve original avec facture ,suit a un abandon de projet ( carte duet 2 3d ,ecran 7 pouce ,etc etc ) le contien 5 moteurs 0.9 degre c bien ,ou je reste sur des moteurs 1.8 degreNema17 Stepper Motor 17HM5417 0.9 degree
merci
I would choose 0.9 motors and 24v power supply.
ok nickel,
I buy her the whole lot,
he has everything at his disposal,
complete lotsok nickel,
Je lui achète alors tout le lot,
il a tout à sa disposition,
lots complet -
Hi
I received the complete part lots
duet3d wifi
screen
motor 0.9
24v power supply
etc., etc .
but before plugging in I have nothing to touch on the duet card,
is there a manipulation for the 12v / 24v? ,
I print the box while waiting for the hunt
(V-Core) Full electronics enclosure for Duet Wifi / Ethernet V2thank you
salut
J'ai reçu les lots de pièces complets
wifi duet3d
écran
moteur 0,9
Alimentation 24v
etc .
mais avant de brancher je n'ai rien à toucher sur la carte duo,
y a-t-il une manipulation pour le 12v / 24v? ,
J'imprime la boite en attendant la chasse
https://www.thingiverse.com/thing:3512961Merci
No there is no voltage selector if that's what you mean. Just connect your PSU to the VIN terminals.
https://duet3d.dozuki.com/Guide/2.)+Wiring+your+Duet/9?lang=en
thank you
I connect everything configure wifi etc etc,
everything worked fine.
but when I reconnect everything,
several lines on panelDue and white screen, no display, I have everything off; I'm thinking about the screen problem? or other I don't know everything?
it is well connected, I have checked everything, maybe we should flash PanelDue?merci
j'ai tout connecter configurer le wifi etc etc ,
tout fonctionnai bien .
mais quand jai tout reconnecter,
plusieur trait sur panelDue et ecran blanc , pas dafichage , jai tout eteint ; Je reflechi probleme de l'ecran ? ou autre je sais pas tout ?
il est bien connecter , j'ai tout verifier , peux etre faut flasher PanelDue ? -
I think the flash I found the same problem on youtube
je pense le flasher j'ai trouvé le meme probleme sur youtube
From the linked thread for that video they eventually used a windows PC to flash.
But if you're using a mac, check this out on getting bossa working in recent macOS versions. https://forum.duet3d.com/topic/11445/flashing-firmware-on-mac-os-x?_=1581893503158
PanelDue Failure
je pense le flasher j'ai trouvé le meme probleme sur youtubeOui.
Si vous ne souhaitez pas utiliser votre Mac, Un Raspberry Pi peut également flasher via bossa.
bossa installer:
sudo apt update && sudo apt install -y libwxgtk3.0-dev libreadline-dev git clone https://github.com/shumatech/BOSSA cd BOSSA make
- Connectez le panneau à Pi avec un câble USB
wget https://github.com/dc42/PanelDueFirmware/releases/download/1.23.2/PanelDue-v3-4.3.bin
~/BOSSA/bin/bossac -e -w -v -b PanelDue-v3-4.3.bin
Devrait fonctionner en moins de deux minutes. Si cela ne fixe pas le panneau, faites de même avec 'PanelDue-v2-7.0C.bin'
And please forgive any of my very rusty french...
it's good flash ok,
with PanelDue-v3-7.0E.bin,
everything is ok, he became himself again,
I had to stay press on erase I don't know?
I'm on windows,
but its going to be useful to the people who follow and who are equip apple.
thank you
I can return following my projectc bon flashe ok ,
avec PanelDue-v3-7.0E.bin ,
tout est ok , il est redevenu lui meme ,
j'avais du rester apuyer sur erase je sais pas ?
je suis sous windows ,
mais sa va servir aux personnes qui suivent et qui sont equiper apple .
merci
je peux retourner a la suite de mon projet -
Hello .
I receive my pieces little by little, it will soon be big big job ,I especially expect the aluminum and the linear rail, the I connect all the electronics etc etc. but I have questions ??
the stepper motor 0.9 degree, I just have to double the steps or I change another parameter? (compared to 1.8 degrees)
i will need a total of 6 nema stepper motor,
2 Z, 1 X, 1 Y, 1U (if I understood correctly for idex)
and 2 for the extruder,
I am obliged to take the extension duex, for an additional nema, or I have another way, its makes me expensive the extension for a single stepper motor, even if I have a lot of possibilities after
.Salut .
Je reçois mes pièces petit à petit, ce sera bientôt un gros gros boulot :),
J'attends surtout l'aluminium et le rail linéaire, le je connecte toute l'électronique etc etc mais j'ai des questions ??
le moteur pas à pas 0,9 degré, je dois juste doubler les pas ou je change un autre paramètre? (par rapport à 1,8 degrés)
j'aurai besoin d'un total de 6 moteurs pas à pas nema,
2 Z, 1 X, 1 Y, 1U (si j'ai bien compris pour idex)
et 2 pour l'extrudeuse,
Je suis obligé de prendre l'extension duex, pour un nema supplémentaire, ou j'ai un autre moyen, ça me coûte cher l'extension pour un seul moteur pas à pas, même si j'ai beaucoup de possibilités après
That's correct. You would need to double the steps per mm compared to 1.8 degree motors.
Thank you
and for the additional stepper motor,
duex extention compulsory?
or can i find something else?Je vous remercie
et pour le moteur pas à pas supplémentaire,
duex extension obligatoire?
ou puis-je trouver autre chose? -
I think in your case the duex would be the best option
You could setup initially with just the Duet Wifi and it's 5 drivers and get the CoreXY working. Then you can decide after how many motors you would need for your IDEX build. Or are you planning and going straight to the IDEX build?
The Duet Wifi has 5 drivers. The Duex2 has an additional 2 drivers, and the Duex5 has 5 more drivers.
I would plan for 3 Z motors to do auto bed leveling, 2 extruders, and then perhaps up to 4 more motors depending on what your CoreXY IDEX arrangement ends up being.
thank you so much for your help,
yes exactly I'm going to mount everything in corexy, and start to prepare everything for the additional chario.
I have only 2 stepper motor for z, so duet2 wifi 5 motor available, I need the extension duex5 in my opinion as its I would be good to add the 3rd stepper motor on z, and I add my missing extruder for chario idex, and i will be ready for the future i thinkmerci énormement pour votre aide,
oui exactement je vais tout monter en corexy, et comencer a tout preparer pour la chario suplementaire.
j'ai que 2 moteur pas a pas pour z, alors duet2 wifi 5 moteur disponible, il me faut l'extention duex5 a mon avis comme sa je serai bien pour rajouter le 3 eme moteur pas a pas sur z, et moi rajouter mon extrudeur manquant pour le chario idex, et je serai parer pour l'avenir je pensse -
Hello to everybody
well it's going well for now,
the most complicated for me will soon arrive
you gave me strength thank yousalut a vous
bon ça avance bien pour l'instant ,
le plus compliqué pour moi va bientôt arriver
vous m'avez donner la force merci -
Hi
good i got my duex5 and everything else i continue my project,
but I have a blockage
it makes me crazy twice I change the bl touch I configure everything,
it comes in it goes out, upon ignition then nothing.
the z burst my 7 inch paneldue,
pff i have more strength
I have more than her to conquer to pass to the additional axis usalut
bon jai recu ma duex5 et tout le reste je continu mon projet ,
mais la jai un bloquage
ça me rend dingue deux fois je change le bl touch je configure tout ,
il rentre il sort , a l'alumage puis plus rien .
le z ma eclater un paneldue 7 pouce ,
pff j'ai plus de force
il me reste plus que sa de conpliquer pour paser a l'axe u suplementaire
