RepRapFirmware 3.01-RC1 released
@SpoonUnit said in RepRapFirmware 3.01-RC1 released:
Any thoughts on the chamber issue? Can I just allocate any random pin to the heater or will there be a check on whether it can actually perform as a heater?
I can't remember whether you can use any pin or it has to be PWM-capable. But your alternative is to use conditional GCode. Don't create a dummy heater, just a sensor. Then loop until the sensor temperature is high enough, e.g. within 5C of the temperature you have set for the bed heater (if your sensors agree that closely).
Items "t" do not work.
@dc42 said in RepRapFirmware 3.01-RC1 released:
OK. Definitely interested in trying that, though the benefit of the chamber definition is lost (i.e. I can see the sensor temp displayed clearly in DWC - but maybe there's another way to add the sensor to the UI?).
Here's what I tried:
echo "starting" while true if heat.sensors[6].lastReading < 30 echo heat.sensors[6].lastReading break echo "bed temp reached"
I tried this as a macro and a gcode file, and neither work. In fact, I think adding the additional echo within the if body and then running the job caused DWC to go into an infinite-reboot-loop. If this isn't the right way to test code, is there an alternative?
I realise the logic is upside down by the way. I've been flipping the >/< while testing.
Just to confirm this is the right sensor to test:
I think what's happening is that the loop is taking up all the processor time. I'll fix this in RC2. Meanwhile, try putting a 1 second delay (G4 P1000 command) in the loop body.
Is there an update for the expansion board as well?
@jay_s_uk said in RepRapFirmware 3.01-RC1 released:
Try the one at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. You might need to use the copy of RRF there too.
Yep. Sorted. Thanks!. I did wonder whether it was just going to get stuck that way. So, the second pause does fix it, and perhaps that's sensible anyway. You're in control about how much to wait between cycles. I guess if you're going to fix it at some value, that value could be set by another GCODE before entering the loop perhaps.
The short piece of code does generate an interesting result on the progress bar
Actually, now I'm a bit confused ...
This was where I (stupidly) put the pause ...
while true if heat.sensors[6].lastReading > 30 G4 P1000 break
But it worked anyway (?), so it paused even without the sensor having the right value.
Also PrusaSlicer isn't terribly excited about the GCODE ..
!!!!! Failed to process the custom G-code template start_gcode
Parsing error at line 18.
if heat.sensors[6].lastReading > 65 -
It seems Slic3r uses [] to denote variables, so if they're found, it immediately tried to process and then fails. I wonder if an alternate form can be made available along the lines of:
heat.sensors.6.lastReading
This then doesn't trip the error. For now I can post process to just put the [] back in.
why not use the macros provided by RRF to do start/stop stuff?
send M308 S1 P"temp1" Y"thermistor" B4725 C7.06E-8
send M308 S1response is
Sensor 1 type Thermistor using pin temp1, reading -273.1, last error: sensor open circuit, T:100000.0 B:4725.0 C:7.06e+0 R:2200.0 L:0 H:0
and the tool fan starts spinning - it should start @50C
@spllg said in RepRapFirmware 3.01-RC1 released:
There's your answer, the firmware can't detect the thermistor. Maybe a bad crimp connection?
send M308 S1results in
Sensor 1 type Thermistor using pin temp1, reading 20.6, last error: success, T:100000.0 B:4725.0 C:0.00e+0 R:2200.0 L:0 H:0
no, i did not change anything except leaving out C7.06E-8 in the first m308 - did not even touch the printer.
@bearer It's a good idea. I can write a few different macros for the few variations I would typically have for startup. Thanks for the suggestion.
@SpoonUnit if you need variety you could still control it from the slicer and have M98 execute the file of your choosing. (not sure if parameters are implemented yet, but think it on the to-do list)
@bearer Yep. That's exactly what I was thinking once you suggested using macros. I already store retraction settings in retraction.g, so this is just an extension of that type of thinking.
@bearer said in RepRapFirmware 3.01-RC1 released:
Oh, you mean parameters for running a macro!. That would be nifty.
@dc42 connected the thermistor to temp2 - same result.
further info:
M308 S2 P"temp2" Y"thermistor" B4725 C.000001
results in
M308 S2
returning
Sensor 2 type Thermistor using pin temp2, reading 12.8, last error: success, T:100000.0 B:4725.0 C:10.00e-7 R:2200.0 L:0 H:0
the same holds true if the thermistor is connected to temp1.
send M308 S1 P"temp1" Y"thermistor" B4725 C0.0000000706
send M308 S1
results in
Sensor 1 type Thermistor using pin temp1, reading 20.3, last error: success, T:100000.0 B:4725.0 C:7.06e-8 R:2200.0 L:0 H:0
the temperature reading is still ~20C @200C
send M308 S1
results in
Strange. I just sent:
m308 s5 p"temp1" Y"thermistor" B4725 C7.06e-8 a"temp1"
to a Duet 3 MB6HC running in standalone mode with an E3D thermistor connected to temp1. In the Extras tab of DWC it reads 23C, which is about right.
Are you running in standalone mode, or with attached SBC? If with SBC, what version of DSF are you running on the SBC?
