duet2, firmware 3 --> bed and 1 heater on TEVO little monster
Post your homing files.
; homedelta.g
; called to home all towers on a delta printer
; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 14:51:14 GMT+0100 (CET)
G91 ; relative positioning
;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
G1 H1 X705 Y705 Z705 F1800 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
;G1 Z-10 F6000 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
;G1 X0 Y0 F6000 ; move X+Y to the centre -
How are you homing when that message happens? From the DWC? Sending G28 in a gcode file?
Can you evoke it again by sending those lines from homedelta manually in the console?
@Phaedrux said in duet2, firmware 3 --> bed and 1 heater on TEVO little monster:
Can you evoke it again by sending those lines from homedelta manually in the console?Hey, guys,
I'm doing a G28 and then I want to put my head down, that's when the message comes.
When I send a gcode file with G28, it works perfectly.
@RafB said in duet2, firmware 3 --> bed and 1 heater on TEVO little monster:
What do you mean by "I want to put my head down,"?
If you press the homeall button in the DWC does it work without error?
If you press the homeall button in the DWC does it work without error?Okay, I just figured it out and everything seems to be working fine.
I was trying to shoot my hothead but I pressed +0.5mm and when I pressed -0.5mm I got the same message.
On the other hand if I do Home(G28) and I press -0.5mm my hothead goes down correctly.Sorry, rookie mistake...
Glad you figured it out.
I wanted to run a print but I still have to put G31 Zx.xx (0.88mm).
I don't understand the difference between Firmware 2 and 3.Can you advise me on this point here? J'ajoute simplement la ligne à Z-probe?
G31 Z0.88Actuel z-probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H6 F200 T2000 ; set Z probe type to bltouch and the dive height + speeds
M557 R150 S20 -
There is no example in the firmware3 wiki. Complicated for a beginner like me
https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_G31
@RafB Refer to the main gcode dictionary: https://duet3d.dozuki.com/Wiki/Gcode#Section_G31_Set_or_Report_Current_Probe_status
Put it in your config.g. eg
; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H6 F200 T2000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y0 Z0.88 ; set Z probe trigger value, offset and trigger height M557 R150 S20
This is where you put your probe XY offset, too. You can use the RRF config tool to produce example code: https://configtool.reprapfirmware.org/
@droftarts Thanks a lot!
I would like to know if it is possible to change the shrinkage values during printing?
@RafB You can use https://duet3d.dozuki.com/Wiki/Gcode#Section_M579_Scale_Cartesian_axes for scaling. However, I don't know the effect of doing this during a print.
