Configure Laser Co2
I have configured a RepRapFirmware for Duet 2 Maestro 3.0 (2020-01-03b3), and I need the H2 to perform the diparo through the GND (-), but it is not activated. I pass the Test File and the config.
Cut.g
; LightBurn 0.9.09
; Marlin device profile, absolute coords
G21
G90
; Cut @ 10 mm/sec, 100% power
M106 S0
G0 X50 Y40 F0
M106 S255
G1 Y60 F600
G1 X76
G1 Y40
G1 X50
M106 S0
G0 X61 Y53 F0
M106 S255
G1 Y79 F600
G1 X97
G1 Y53
G1 X61
M106 S0
G0 X76 Y69 F0
M106 S255
G1 Y93 F600
G1 X108
G1 Y69
G1 X76
M106 S0
G0 X93 Y72 F0
M106 S255
G1 Y93 F600
G1 X140
G1 Y72
G1 X93
M106 S0
G0 X92 Y81 F0
M106 S255
G1 Y105 F600
G1 X125
G1 Y81
G1 X92
M106 S0
G0 X89 Y88 F0
M106 S255
G1 X122 F600
G1 Y55
G1 X89
G1 Y88
M106 S0
G0 X103 Y94 F0
M106 S255
G1 Y112 F600
G1 X134
G1 Y94
G1 X103
M106 S0
G0 X116 Y101 F0
M106 S255
G1 Y120 F600
G1 X151
G1 Y101
G1 X116
M106 S0
G0 X118 Y101 F0
M106 S255
G1 X151 F600
G1 Y67
G1 X118
G1 Y101
M106 S0
G0 X115 Y109 F0
M106 S255
G1 X147 F600
G1 Y82
G1 X115
G1 Y109
M106 S0
G90
; return to user-defined finish pos
G0 X0 Y0 F0CONFIG.G
; Configuration file for Duet Maestro (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Jan 29 2020 20:11:58 GMT+0100 (hora estándar de Europa central); General preferences
M550 P"MK1 Laser" ; set printer name; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S1 ; enable TelnetM307 H2 A-1 C-1 D-1 ; disable heater 2 so we can use its pin to drive a Laser
M452 P2 S1 R125 F5000 ; laser mode 5000 laser; Drives
M584 X0 Y1 ; set drive mapping
M350 X16 Y16 I1 ; configure microstepping with interpolation
M92 X160.00 Y160.00 ; set steps per mm
M566 X1200.00 Y1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y6000.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 ; set accelerations (mm/s^2)
M906 X900 Y1400 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X0 Y0 S1 ; set axis minima
M208 X900 Y600 S0 ; set axis maxima; Endstops
M574 X1 Y1 S0 ; set active low and disabled endstops; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M140 H-1 ; disable heated bed; Fans
M106 P0 S0 I0 F200 H-1 x118 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
G10 P0 X0 Y0 ; set tool 0 axis offsets
M501
Thank you
I had to do Downgrade at 2.04, and before starting to do the job, I have to send by console M3 S255, to turn on the Heater, and that is how it works. Otherwise or just sending M3, shooting does not work. I don't know if something will be wrong.
Thank you
Turning the laser on/off using M106 fan commands is a very old approach, intended for firmware that can't handle anything better. I suggest you configure Lightburn to generate G1 commands with S parameters to control the laser instead.
thanks for your reply
Ye have modified LightBurn and the code comes out with the M3, as I had indicated. Send example.
; LightBurn 0.9.09
G21
G90
; Scan @ 300 mm/sec, 20% power
M05
G0 X41.63 Y88.14 F0
G91
M03 S51
G1 X-0.97 F18000
M03 S0
G1 X-4.26
M03 S51
G1 X-0.87
M03 S0
G1 X-4.11
M03 S51
G1 X-1.03
M03 S0
G1 X-0.33 Y-0.1
M03 S51
G1 X1.69
M03 S0
G1 X3.46
M03 S51
G1 X1.49
M03 S0
G1 X0.88
M03 S51
G1 X0.76
M03 S0
G1 X2
M03 S51
G1 X1.68
M03 S0
G1 X1.17
M03 S51
G1 X0.89
M03 S0
G1 X1.11
M03 S51
G1 X0.87
M03 S0My question now is ... to fire the laser, I have the PWM of the fan controlling the (IN) Imput 0-5 V.
What output do I have to connect to TH of the laser power supply ??? GND H2 ??? or positive + H2 ???
Thank you.
P.D .: Sending photo connection of the power supply
Marlin doesn't understand G1 commands with S1 parameter, so it is not an appropriate profile to use.
@dc42 Very funny and sorry that I have to bother again, but something I do not understand.
You are not sending the G1 command with parameter S1. Or I did not understand something.
I send a piece of a Gcodec, to tell me where the error is, by using the M3 command with the S1 parameter that Gcodec, or do I have to modify something in the config.g ????
I keep looking, but I don't see the error it refers to.
Any help please?
Thank you
If LightBurn doesn't have a device profile for RepRapFirmware, try a profile for Smoothieware. That should generate G1 commands with S parameters to set the laser power.
I tried Ligtbrurn with the Smoothieware profile and generated the Gcodec that I put next. Is this seriously correct? Can something better be done to get more performance when recording with the Duet with other software?
; LightBurn 0.9.09
; Smoothieware device profile, absolute coords
G00 G17 G40 G21 G54
G90
M3
M106
G0X115.81Y96.3
G91
G1X-4.62F18000S51
G1X-0.05Y-0.1S0
G1X4.72S51
G1X0.06Y-0.1S0
G1X-4.84S51
G1X-0.06Y-0.1S0
G1X4.96S51
G1X0.06Y-0.1S0
G1X-5.08S51
G1X-0.05Y-0.1S0
G1X5.18S51
G1X0.06Y-0.1S0
G1X-5.3S51
G1X-0.06Y-0.1S0
G1X5.42S51
G1X0.06Y-0.1S0
G1X-5.54S51
G1X-0.06Y-0.1S0
G1X5.66S51
G1X0.05Y-0.1S0
G1X-5.76S51
G1X-0.06Y-0.1S0
G1X5.88S51Thank you
That's much closer to ideal. The laser is being controlled by S parameters on the G1 commands. Some of the commands at the start are odd (e.g. M106 with no parameters), but harmless.
What issue do you have with performance?
We are a group in Spain of more than 20 people, we have mounted a CO2 laser and mine, is the first that is working. We have installed Duet2D Maestro and we are looking for a software that generates a Gcodec completely compatible with Duet and the Laser.
We have acquired some already LightBurn, but we are not having good results, we do not know if the culprit is the adjustment of the Duet or it is of the Software, since with a Laser K40 and plate of very little quality, it was obtaining better results with K40 Wisperer.
Maybe we have to make some adjustments or change the software.
https://photos.app.goo.gl/gz8XiZ7GXHnrQg7h6
https://photos.app.goo.gl/KrJzu9yycSjMEtMf6
Could you make some recommendations?
Thank you very much.
P.S.: Sorry, but I don't know English and I use Google translator.
@juanmena
You might want to read this thread: https://forum.duet3d.com/topic/12150/laser-gcode-s-sticky-after-g0-question, there is some discussion of how to configure LightBurn with Duet/RRF Firmware. The bad news is that there is no built in 'compatibility' for the Duet in LightBurn.Currently I use LaserWeb; (but I control a Grbl CNC, not Duet, so cannot give a config).
https://github.com/LaserWeb/LaserWeb4LaserWeb is very good at preparing raster and dither images from bitmaps and jpeg's etc. And at cutting and filling svg (vector) images. But it has no image editing tools beyond resizing and rotating them. So I often use Pinta or InkScape to prepare the source material first.
LaserWeb can run as a standalone application on your laptop/pc to generate Gcode and optionally control/stream to the firmware via USB or telnet if desired. Look for the windows 'electron' build.But I use it it on a Raspberry PI in web client/server mode to give myself a webUI.
Since you can configure all headers etc with laserweb it is much easier than LightBurn to configure for a Duet. The inbuilt RRF profile is a good start.
@EASYTARGET Thanks for answering.
I've been installing and testing and that's why I've been slow to answer.
LaserWeb, generates a Gcode without the G1 in front of each line and the Duet, does not respond to these movements. For the rest, it seems that it could be worth it, but without that, it does not move in conditions. Step example of what it generates ...
G1 X2.15 Y2.15 S0.0000
X21.95 S0.3129
Y2.45 S0.0000
X21.80 S0.6872
X2.30 S0.7000
X2.15 S0.4841
Y2.75 S0.0000Those lines are not valid for Duet.
Let's see if someone can help me, because I think I'm going to have to leave Duet for the Laser.
Good morning,
First of all I want to thank all the help I'm getting, but it's not working for me, I think the installation is correct, and I apologize for what could bother me with so many questions, but I would not like to leave the project.
I will explain my approach and the duas.
The first thing is to check the installation I have is the correct one, or I would have to change to option 2 or some other cable. The PWM always goes through a converter board
My installation (Duet - Laser power supply)
FAN0 - FAN0- <> Signal Ground GND
FAN0 - V_FAN_A <> Imput Control Signal (0-5V)
E1 HEATER - E1- <> Switch Laser Control (Active Low)I am asking if option 2 would be more correct, connect E1 HEATER - E1- <> Imput Control Signal (0-5V)?? and activate "Switch Laser Control (Active low) with another PIN that acts directly on/off with M3/M5?
I pass photos:
E1 may be doing PWM by the Switch Laser Control (Active Low) PIN
from the laser power source?Is this Gcode format correct?
; LightBurn 0.9.09
G00 G17 G40 G21 G54
G90
M3
M106
G0X115.81Y96.3
G91
G1X-4.62F18000S51
G1X-0.05Y-0.1S0
G1X4.72S51
G1X0.06Y-0.1S0
..........I've been looking at this post, but I think it was talking about K40 and yet I think this laser power supply, could it be connected differently or am I on the wrong track?
Thank you very much again
@juanmena said in Configure Laser Co2:
X21.95 S0.3129
Y2.45 S0.0000
X21.80 S0.6872
X2.30 S0.7000
X2.15 S0.4841
Currently, RRF recognises that style of command in CNC mode but not in Laser mode or FFF mode. I will change it in RRF 3.01RC2 to recognise those commands in Laser mode too.
