Duet 3 w/Raspberry Pi - Failed to delete, JSON Parse Error
Not sure if this is a DWC, DSF, or RRF issue. Whenever I go to delete a file using DWC, I get this message.
Happens with anything, .gcode files from the Jobs section, Macros, even if I delete config.g.bak
It appears to actually be deleting the file, if I hit refresh it's gone.
duetcontrolserver 1.2.3.1 duetruntime 1.2.3.1 duetsd 1.0.5 duetsoftwareframework 1.2.3.1 duettools 1.2.3.1 duetwebcontrol 2.0.6-1 duetwebserver 1.2.3.1 reprapfirmware 1.2.3.1-1
DWC shows it's 2.0.6, DSF is 1.2.3.1 and RRF is 3.0
Please upgrade to DWC 2.0.7. There was an issue in DWC 2.0.5 and 2.0.6 that caused this kind of error.
I'm guessing I can't do that wile a job is running? I'll update and check back in around 20 hours.
DWC 2.0.7 fixed it. Thanks.
@blt3dp said in Duet 3 w/Raspberry Pi - Failed to delete, JSON Parse Error:
I was curious so I uploaded 2.0.7 during a print and it worked fine.
