RepRapFirmware 3.01beta1 released
@dc42 said in RepRapFirmware 3.01beta1 released:
@gtj0 said in RepRapFirmware 3.01beta1 released:
Thanks for confirming. FWIW, maximum GCode line length excluding leading white space, line number and checksum (if present) and comments is currently 160 characters.
Are you sending them via text message???
Hadn't you noticed your smartphone bills going up every time you print?
Ah that makes sense now. I though it was the cat texting his buddy across the street.
@kraegar said in RepRapFirmware 3.01beta1 released:
Here is the version that works well:
I like this, but it seems unnatural to have to repeat the same G30 commands twice in the same script. This is more significant with a delta printer (that often has many more probe points.)
I'm wondering what alternatives might exist. I see there's no do/while (which would be my first thought), but I'm wondering if it would work to put the list of G30 gcodes in a different file (bed-probes.g)
@dc42, do the variables from the object model available survive across different scripts? For example, if I had file called "bed-ProbePoints.g" that contained something like:
G30 P0 Xn Yn ... G30 P18 X0 Y0 S6
And then my bed.g contained:
M561 G28 M98 P"bed-ProbePoints.g" while true if iterations > 5 abort "something needs tightening..." if abs(move.initialDeviation.deviation - move.calibrationDeviation.deviation) <= 0.01 break M98 P"bed-ProbePoints.g"
Would this work? Would the deviation values be updated across the scripts?
Thank you
Gary -
@garyd9 This was my very rough first iteration (and still is early, room for improvement, etc etc). Only posted in this thread due to the bugs I was noticing.
Anyway, see my post here where I did split the G30 segment out into a macro:
https://forum.duet3d.com/topic/13890/auto-tramming-a-railcore-using-conditional-gcode -
@kraegar That is great (and answers my question.)
thank you
You've found a bug (the property table wasn't ordered alphabetically after I renamed a property, so the binary search failed). I've fixed it in the latest build at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. I also added a compile-time check to prevent this happening in future, and an extra property state.upTime.
Firstly, thanks for the quick response. I've tried the fixed firmware and it works great.
Another thing, I use an ATX type 24V supply controlled by the PS_ON pin.
After all axis are homed, if I turn of the 24V supply, the axis remain homed "Blue" on the DWC. If I turn on the ATX supply again I can move all axis as if they are homed. Shouldn't turning of the 24V supply automatically mark all axis as homed : false?m409
{"key":"","flags":"","result":{"boards":[{"firmwareFileName":"Duet2CombinedFirmware.bin","firmwareVersion":"3.01-beta1+1","iapFileNameSD":"Duet2CombinedIAP.bin","mcuTemp":{"current":39.6,"max":39.9,"min":38.0},"name":"Duet 2 WiFi","shortName":"2WiFi","vIn":{"current":0.7,"max":24.4,"min":0.4}}],"heat":{"coldExtrudeTemperature":160.0,"coldRetractTemperature":90.0,"heaters":[{"current":22.0,"sensor":0,"state":"Off"},{"current":23.2,"sensor":1,"state":"Active"}],"sensors":[{"lastReading":22.0,"name":"","type":"Thermistor"},{"lastReading":23.2,"name":"","type":"Thermistor"}]},"job":{"file":{"filament":[],"firstLayerHeight":0.0,"generatedBy":"","height":0.0,"lastModified":"28115-10-29T03:41:51","layerHeight":0.0,"numLayers":0,"printTime":0,"simulatedTime":0,"size":0},"lastFileName":"","layer":0,"timesLeft":{"filament":0.0,"file":0.0,"layer":0.0}},"move":{"axes":[{"homed":true,"letter":"X","max":300.0,"min":0.0,"userPosition":70.000,"visible":true},{"homed":true,"letter":"Y","max":300.0,"min":0.0,"userPosition":265.000,"visible":true},{"homed":true,"letter":"Z","max":350.0,"min":0.0,"userPosition":4.213,"visible":true}],"calibrationDeviation":{"deviation":0.000,"mean":0.000},"currentMove":{"requestedSpeed":0.0,"topSpeed":0.0},"daa":{"enabled":false,"minimumAcceleration":10.0,"period":0.0},"idle":{"factor":0.7,"timeout":30000},"initialDeviation":{"deviation":0.004,"mean":0.014},"meshDeviation":{"deviation":0.032,"mean":0.099},"printingAcceleration":10000.0,"speedFactor":100.0,"travelAcceleration":10000.0},"network":{"interfaces":[{"actualIP":"192.168.1.142","firmwareVersion":null,"gateway":"0.0.0.0","subnet":"0.255.255.255","type":"wifi"}]},"state":{"currentTool":0,"machineMode":"FFF","status":"Off","upTime":193}}} -
@insertnamehere said in RepRapFirmware 3.01beta1 released:
Yes. I will fix that.
With the build from your dropbox...Error: in file macro, line 18 column 12: unknown value abs
The line in question:
if abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.02
@garyd9, try enclosing the whole expression in { } so that the round brackets are not treated as enclosing comments.
The deviation value is RMS so it is always positive, unlike the mean.
I've just put 3.01-beta1+1 (2020-01-17b3) binaries at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. These support additional OM variables, including extruder parameters such as pressure advance.
The format for driver IDs may change in future beta releases. I am currently returning strings such as "3.1" for driver 1 on board 3; but I may change this to return 301 in this case, i.e. 100*board_id + driver_number. Whichever I choose, I will allow the format returned by the OM variable to be used in M584, M569 etc.
If you are taking votes/opinions, overall compatibility with the pin labeling nomenclature seems desirable.
About being positive, that's true, but the difference between means might be negative, so I want to get the absolute value of the difference...
As for using curly braces, I'm not having much luck with that. Perhaps because I'm not quite sure where, exactly, the curly braces should be. Here's some of the things I tried, followed by the resulting error:
if {abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.002}
Error: in file macro, line 16 column 91: expected ')'if abs{(move.calibrationDeviation.deviation - move.initialDeviation.deviation)} < 0.002
Error: in file macro, line 16 column 11: unknown value absif abs{move.calibrationDeviation.deviation - move.initialDeviation.deviation} < 0.002
Error: in file macro, line 16 column 11: unknown value absif abs({move.calibrationDeviation.deviation - move.initialDeviation.deviation}) < 0.002
Error: in file macro, line 16 column 12: unknown value abs{if abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.002}
Error: Bad command: {if abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.002}To be absolutely clear, my intention is to get the absolute value of the difference of the two deviations, and compare that to 0.002
@garyd9 said in RepRapFirmware 3.01beta1 released:
I get no error with the format above. Running:
Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.01-beta1+1 (2020-01-17b3)
@Danal said in RepRapFirmware 3.01beta1 released:
Odd. I'm also running "3.01-beta1+1 (2020-01-17b3)". Perhaps because I'm running it on a Duet2 (duet wifi)?
I'll try again in 5-6 hours (if I'm still awake) when my current print finishes...
I will say that I'm starting to wonder if I should "upgrade" to a duet3. While I really don't need the extra ports or capabilities, the newer versions of RRF3 seem to bog down the older boards. I started to get hiccups on my delta at even only 150mm/sec movements now.
Yeah, and I'm running a Pi. It is very unclear to me how much gcode is processed on the DSF on the Pi vs actually being passed to the Duet.
GCodes commands are pre-parsed on the Pi, but most of them are just passed in the parsed state to the Duet. A few such as M98 and M32 are processed partly on the Pi.
I am currently looking at the why RRF3 has hiccups at lower step rates than RRF2.
Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.01-beta1+1 (2020-01-17b3)I've confirmed that I DO get an error similar to "Error: in file macro, line 22 column 90: expected ')'" with the same statement (followed by a newline, tab, and 'break' statement':
if{abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.002}
I'm using a Duet Wifi 1.04 with firmware "RepRapFirmware for Duet 2 WiFi/Ethernet 3.01-beta1+1 (2020-01-17b3)" (No SBC option exists.) I wonder if the same problem exists for non-SBC Duet3 users.
I couldn't get abs to work either, so just nested the if statements. Ugly, but I figured it was something I was doing wrong. Also testing on a duet2.
I confirm there is a problem with functions. Looking into it now.
When I am running my macro " Conditional auto bed levelling using 3 Z motors" an error message is displayed during execution, "RESPONSE TOO LONG SEE CONSOLE".
Nothing is reported in the console log and the macro continues anyway.
Just thought you should know.; Conditional auto bed levelling using 3 Z motors
M561 ; clear any existing bed transforms
if heat.heaters[0].current <60
M291 P"Preheating to bed to 65 and nozzle to 195 for accurate probing"
M140 S60 ; Set bed temperature to 60
M116 ; waiting for bed to reach temperature
if heat.heaters[0].current <65 || heat.heaters[1].current <190
M140 S65 ; Set bed temperature to 65
G10 S195 ; Set current tool temperature to 195C
M116 ; waiting for bed and nozzle to reach temperature; If the printer hasn't been homed, home it
if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
G28G1 Z7.5
;Run an initial 3-point Probe
M291 P"auto bed levelling using 3 Z motors started"
M98 P"0:/macros/Conditional/bedlevel.g"
while true
if iterations = 5
abort "Too many auto calibration attempts"
echo "iterations = ", iterations
if move.initialDeviation.deviation < 0.01
if move.calibrationDeviation.deviation < move.initialDeviation.deviation + 0.005
if move.calibrationDeviation.deviation > move.initialDeviation.deviation - 0.005
break
echo "Repeating calibration because initial deviation (" ^ move.initialDeviation.deviation ^ "mm) must be < 0.01"
echo "and (" ^ move.calibrationDeviation.deviation ^ "mm) must be within 0.005 of initialDeviation"M98 P"0:/macros/Conditional/bedlevel.g"
echo "Auto calibration successful, deviation", move.calibrationDeviation.deviation ^ "mm"
echo "Auto calibration successful, initialDeviation", move.initialDeviation.deviation ^ "mm"M140 S0 ; Set bed temperature to 0C
G10 S0 ; Set current tool temperature to 0C
G1 X150 Y100; Move to bed centre
G30; reset Z0G1 X50 Y230 F24000 ; move the head to park
M291 P"auto bed levelling using 3 Z motors completed" -
Probably kicking in an open door, but just in case it might help: M409 or the rr_model HTTP returns a quite empty object on firmware 3.01-beta2+1 (2020-01-24b1) on Duet2:
{"key":"","flags":"","result":{"boards":[{}],"fans":[{},{}],"heat":{},"job":{},"move":{},"network":{},"sensors":{},"state":{},"tools":[{},{}]}}
Accessing the OM from Gcode works; 'echo boards[0].firmwareFileName' returns 'Duet2CombinedFirmware.bin'
No problem, beta firmware etcetera. I justed wanted to check if I could access tool setpoint temperatures.
