tool change macro issue
This is a real long shot... I have seen a few oddities in R3 with toolchange macros solved by putting an M400 at the beginning of all the macros.
Again, not a good fit for your exact symptom, but it is very quick to try.
@Danal Thanks for the suggestion.
For a minute, I thought it had fixed it. I turned the machine on this morning, added an M400 to the beginning of the two macros (tpre0 and tpre1) and it was working like a charm.
Then I made some modifications to them (I made them call another macro that does the actual servo moves) but I left the M400 in (and added it to the other macros as well).
It worked for a while, until a reboot and now it's all broken again.
I changed it back to just the M400 and M280 P0 S110 and it still doesn't work.
From looking at the queue in the M122 output, it looks like it is continuing to read past the EOF of the macro.
There is some garbage in the queue that appears to be code from previous revisions of the macro.
So, I tried putting an M99 at the end of the macro figuring that would make it exit even if it is ignoring the EOF.
That unfortunately didn't fix it. The queue is still showing some gibberish after the gcode:
Queued 'M280 P0 S58�D�M�>(��F��a��hgM6"��V�(�D'r�?�G�n$������~UT' for move 7I can't figure out why it was working for a little while and now it isn't.
Please check that the problem still occurs in 3.01beta1. Then post your config.g file and tool change files.
I realize this appears to be a flaw with the end of the tpre... nonetheless, may we see your tpost and tfree as well?
And, even longer shot... M400 at beginning and end of each.
Oh, and HUGELY long shot. Format a different SD and copy everything over.
Tfree for both tools is empty (just comments at the top):
; tfree1.g
; called when tool 1 is freed
; generated by RepRapFirmware Configuration Tool v2 on Thu Jan 10 2019 13:50:44 GMT-0500 (EST)There is no tpost for either tool.
I had been thinking of the SD card route. I just got a new SD card and tried it (I backed the old one up with tar and unpacked it onto the new card).
Same deal.I just deleted the tfree files so that there are only tpre macros. Same behavior.
I added M400 to the end of both the macros (after the M99 so it should theoretically be skipped anyway). No change.
I added it before the M99, still the same.Interestingly, the selected tool does change in the web UI. If I attempt to move the machine (G0 Z100 for example), the machine does not move but the web UI location does change.
I seem to have found a workaround. I'm not sure if it will continue to work.
I changed the macro to have a relative move before and after the M280 servo command. Suddenly it started working.
So, now my code is:M400 G91 G0 Z5 F4000 M280 P0 S110 G0 Z-5 M400 M99
Nevermind. I made another change to the config.g (reduced the extruder cooling fan speed to make it quieter) and now it isn't working again.
Strange... -
And interestingly, the symptoms in the output from M122 are different:
Now it gets stuck with:
Segments left: 1
Movement lock held by http
http is doing "M280 P0 S110" in state(s) 0 11, running macro1/16/2020, 12:46:14 PM m122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-beta1 running on Duet Ethernet 1.02 or later Board ID: 08DGM-9T6BU-FG3S0-7JTDD-3S06T-1B4ZF Used output buffers: 3 of 24 (11 max) === RTOS === Static ram: 27984 Dynamic ram: 92600 of which 0 recycled Exception stack ram used: 480 Never used ram: 10008 Tasks: NETWORK(ready,644) HEAT(blocked,1240) MAIN(running,1844) IDLE(ready,76) Owned mutexes: === Platform === Last reset 00:00:53 ago, cause: software Last software reset at 2020-01-16 12:45, reason: User, spinning module GCodes, available RAM 10008 bytes (slot 2) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 23.4, current 23.6, max 24.2 Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max not available Driver 1: standstill, SG min/max not available Driver 2: standstill, SG min/max 221/370 Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Date/time: 2020-01-16 12:46:10 Cache data hit count 91184188 Slowest loop: 2.36ms; fastest: 0.09ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 166, MaxWait: 36518ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 7, completed moves: 4, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 1 Movement lock held by http http is doing "M280 P0 S110" in state(s) 0 11, running macro telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 8.20ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 Interface state 5, link 100Mbps full duplex
It is currently working again. I'm not sure what happened. I thought the problem might have been that my homeall.g called my homez.g with an M98 with no quotes around the filename. I modified my homeall to not call the homez (and a few other tweaks) and everything suddenly started working. But, when I put the bad M98 back in (with no quotes, just to see if it would fail), I couldn't reproduce the problem.
