BLtouch with Reprap Firmware 3.0
Funny, I just ( about 20 min ago) got this working for myself.
I'm sure there are still things wrong with my config.g but you can look at it here. I would also have you look at the Duet/BLTouch guide posted here. You didn't mention which Duet board your using but lets just say its the Duet 2 Wifi. Look at the wifi section of that page. Pay special note to where to connect the BLTouch to the board. Heater3 in the case of the Duet 2 Wifi. If you connect your BLTouch to those pins, and use the probe section from my config, you should be good:
M950 H3 C"nil" ; Disable heaters h3-h7 to free up pins M950 H4 C"nil" M950 H5 C"nil" M950 H6 C"nil" M950 H7 C"nil" ; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H10 F800 T2000 ; set Z probe type to bltouch and the dive height + speeds
The M950's with the C"nil" are there to free up those pins. You only really need to free up H3 for the BLTouch in this case, but I figured I wasn't using those so I'd free them all up.
Let me know if you have any questions
Ok I am using Heater3
Duet Wifi 2
here is my updated config; BLTouch - Heaters
;M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.; Z-Probe
M950 H7 C"nil" ; Disable heaters h7 to free up pins
G31 X20 Y0 Z3.3 P25 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
M557 X15:215 Y15:195 S20 ; define mesh gridHere is my homeall setup
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v2.1.5 on Wed Jan 08 2020 19:38:55 GMT-0500 (Eastern Standard Time)M913 X75 Y75 Z100 ; reduce motor power
M400 ; make sure everything has stopped before we make changes
M915 H400 X Y S0 R0 F0 ; set X and Y to sensitivity 0, do nothing when stall, unfiltered
M574 X1 Y1 S3 ; set endstops to use motor stallG91 ; use relative positioning
G1 H2 Z5 F6000 ; lift Z relative to current positionG4 P500 ; wait 500msec
G1 H1 X-285 F2000 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 ; move away from home
M400 ; make sure everything has stopped before we make changesG4 P500 ; wait 500msec
G1 H1 Y-285 F2000 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 ; move away from home
G1 H1 Y-285 F2000 ; move quickly to Y axis endstop and stop there (first pass)G1 H2 Z10 F6000 ; lift Z relative to current position
G1 X150 Y150 F1200 ; Centre Print head
G1 H1 Z-305 F1800 ; move Z down until the endstop is triggered
G92 Z0 ; set Z position to axis minimum (you may want to adjust this)G1 H2 Z10 F6000 ; lift Z relative to current position
M913 X100 Y100 ; XY motors to 100% current
G90 ; back to absolute positioningCurrently im getting this error
G28 SetPosition called when DDA ring not emptyfor wiring I have the BLTOUCH
White Wire (Z signal) = Z Probe IN
Orange (Servo Sig) = Heater3
Red (5v) = +5V
Brown (GND) = GND -
That looks good.. These V3 /config.g files are complicated. More so than with versio 2.x I think. Have you tried it
@Adamfilip said in BLtouch with Reprap Firmware 3.0:
One change.. Change:
M950 H7 C"nil" ; Disable heaters h7 to free up pinsto
M950 H3 C"nil" ; Disable heaters h3 to free up pins
I managed to get it to deploy in tests but when I run homeall
it gets to the point where it centers the headthen it gives me the error
G28 SetPosition called when DDA ring not empty -
Hallo, can you over a Macro or a G-Code push the BLTouche Pin in or out.
I have the BLTouch config like you and the BlTouch don´t move the Pin. -
; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 09:19:35 GMT+0100 (Mitteleuropäische Normalzeit); General preferences
M550 P"My Printer" ; set printer nameM667 S1 ; select CoreXY mode
M551 P"123456" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P4 S1 ; physical drive 4 goes forwards
M584 X0 Y1 Z2 E3:4 ; set drive mapping
M92 X80.00 Y80.00 Z4000.00 E415.00:415.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1400 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X400 Y400 Z500 S0 ; set axis maxima; Endstops
;M574 Z1 S2; BLTouch - Heaters
;M307 H3 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.; Z-Probe
M950 H3 C"nil"
;M950 H4 C"nil"
;M950 H5 C"nil"
;M950 H6 C"nil"
;M950 H7 C"nil" ; Disable heaters h7 to free up pins
M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
M557 X50:350 Y50:350 S50 ; define mesh grid; Heaters
M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M143 H2 S280 ; set temperature limit for heater 2 to 280C
M307 H2 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit; Fans
M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H1:2 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M563 P1 H2 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossI have the BLTouch wired on Heater3 (PIN8) on the Duet Wifi Board.
i take the G-Code to test M401 / M402
or
M280 P3 S10 I1
M280 P3 S160 I1
M280 P3 S120 I1
nothing move it.With the old Firmeware 2.05 the Pin Move in and out.
@CupaCabra said in BLtouch with Reprap Firmware 3.0:
Have you also adapted deployprobe.g and retractprobe.g?
M280 P3 S10 I1
M280 P3 S160 I1
M280 P3 S120 I1Now you have to use
M280 P0 S10
M280 P0 S160
M280 P0 S120 -
yes i have but i don´t now is it right.deployprobe.g
M280 P3 S10 I1and in retractprobe.g
M280 P3 S90 I1i hope there are right
change P3 to P0 and remove I1
@DIY-O-Sphere
i change the Code in the Config now an test it. -
It´works with
M280 P3 S10 ......thx so lot
@CupaCabra Great! Please post the 'Z-Probe' section of your config.g to show how you resolved this!
Also, you don't need to unassign the heater channels in RRF3 with
M950 H3 C"nil"
, as they are not assigned by default. Only a few pins are assigned by default, and only need to be unassigned if you use them for something else; see https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Duet_2_WiFi_Ethernet_and_Duet_2_MaestroIan
M280 P3 S10 ......
Now I am confused.
You will find exact your configuration in
https://duet3d.dozuki.com/Wiki/Gcode#Section_M280_Set_servo_positionAnd we have done it succesfully on a buddys wifi exact that way with heater7.
Are you shure you have update to the stable and not to a older beta.
I think there you had to trigger the heater instead of the servo channel. -
@droftarts said in BLtouch with Reprap Firmware 3.0:
Also, you don't need to unassign the heater channels in RRF3 with M950 H3 C"nil"
The beta would explain that too.
so i have change the
deployprobe.g
M280 P3 S10retractprobe.g
M280 P3 S90if i test with a Marco file
The pin go´s out with S10 und retract with S90I think it´s right.
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
the
Firmware : 3.0 (2020-01-03b3)
WiFi Server Version: 1.23
Web Interface: 1.22.6 -
Thanks to this thread I've made progress getting my BLtouch to work. I do have a few questions still.
Basic info:
Duet WiFi 1.02 running RRF3
BLtouch V3.1The BLtouch is wired as follows:
Red (5v) = +5V
Brown (GND) = GNDQuestions (I have googled, but can't find clear answers anywhere):
- When I start the printer, the BLtouch performs a self test. This results in the pin being up, and the red led on the BLtouch being on. Is that correct?
- When I do a M280 P0 S10 the pin drops. The red led is off, but a blue led is on now. Is that correct?
- M280 P0 S10 I1 gives the same result. Is it supposed to work with and without the I1 parameter?
- M280 P0 S90 retracts the pin, the red led is on as well as the blue led. Is that correct?
Thanks in advance!
