Z axis issue: wrong movement (layers)
@Phaedrux
I've shorter 8mm pitch lead screws. I'll try with them. -
@zecchi said in Z axis issue: wrong movement (layers):
2mm pitch.
Well there goes that theory.
With a 2mm lead, and 1.8 degree motors (deduced from your 1600 steps per mm on Z) your full step resolution is 0.01mm. So you have no limits there.
What are the motor specs?
@Phaedrux
So, if my layer height is 0.2mm isn't a problem, correct?Motor: 1.5A , 1.8°. Classic 17HS4401 stepper motor.
@Phaedrux
So, if my layer height is 0.2mm isn't a problem, correct?Correct
I'm unable to find a data sheet that seems close. There are many sub-models of 17H4401 between many manufacturers. I didn't even see any that were 1.5a.
Can you find a data sheet that seems to match your motor based on what you know about it?
@Phaedrux
Second line of this datasheet:
17HS2408-MotionKing.pdfNow I realize that the seller made fun of me selling this motor as 1.5A instead 1.3A (I re-cecked and in the description is written 1.5A ).
@zecchi
My fault , the line is actually the number eight. So the current is 1.7A. awesome.This is the link :
€ 21,62 20%OFF | Nema17 Stepper Motor 42 motor Nema 17 motor 42BYGH 1.5A 38mm 17HS4401 motor 4-lead for 3D printer CNC
https://a.aliexpress.com/BBHPrX2gL -
This is the response to M122 command:
If you see something strange ,please let me know.
Everything looks good to me. I think it is mechanical though. I went through a similar ordeal with my own Z axis a while ago. There was a repeating pattern. It wasn't exactly like your pattern but similar in nature. I ended up tearing the entire Z axis apart and replacing many of the chinese belts, pulleys, idlers, lead screws with better quality alternatives as I suspected some eccentricities in the pulleys and possibly some misalignment or bend in the lead screws. I was able to get it mostly eliminated, but it could still be seen in certain lighting conditions, but more faintly.
Take it apart. Inspect everything. Roll the lead screws on a flat surface. Check the couplers and pulleys. Test the motors and feel how they move in your fingers. Try different motors.
Is this issue dependent on layer TIME at all?
IE, if a series of layers take the same time, the pattern repeats evenly, but if the layers vary in time, the pattern has a different frequency?
I think it could be your bed heater heater model/thermistor settings. Are you using the same thermistor in your heat bed as for your hotends? Your config indicates this. I don't see any heater model parameters in your M307 command for the bed heater. This would be using the default heater model, which is based on an e3d V6, no?
Many heating elements can expand and contract, or rather distort and contort in different ways, causing the position of the Z axis to vary slightly. Better tuning of the heater could help, if this is the case.
@Phaedrux said in Z axis issue: wrong movement (layers):
This is absolutely ok. It has been my first test.
@bot said in Z axis issue: wrong movement (layers):
I don't think so. Rather it depend on height of the model: different models same errors at same height.
Yes , I'm using e3d V6. I'll try to repeat auto-tuning of PID for the nozzle. Maybe the error is due by the instable temperature.
Have you pid tuned the bed as well? Bang Bang mode on the bed could cause some up and down motion via warping and expansion.
@Phaedrux I think it’s worse than that. The user seems to be using pid with the bed but using default parameters. This may not be worse than bang bang but it could very well be.
I don’t think the user understood what I was saying. Tuning the bed PID or trying bang bang was my suggestion, basically. I’m so bad at wording posts.
Yeah , it is. I've never tuned the bed because I never use it (At least for now ).
@zecchi Sorry about that. If you're not heating the bed that is clearly not a factor.
Today I'll try the new z axes. I set up them yesterday. My last chance...
And here we go!!
The problem were the two z axis.
Maybe it was due to the elasticity of the belts!!Thanks to all.
Congrats on solving the issue.
A question out of curiosity, what did you change in your Z axis?
