RepRapFirmware 3.0RC2 now available
Ok cheers!
Doing sudo apt-get update and then apt-get upgrade gives this error on reprap firmware package.
Setting up reprapfirmware (1.2.2.0-1) ... [error] Failed to connect to Duet System.IO.IOException: Error 16. Cannot put line into event mode. at LinuxDevices.InputGpioPin..ctor(String devNode, Int32 pin, String consumerLabel) in /home/christian/duet/DuetSoftwareFramework/src/LinuxDevices/InputGpioPin.cs:line 60 at DuetControlServer.SPI.DataTransfer.Init() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 65 at DuetControlServer.SPI.Interface.Init() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 65 at DuetControlServer.Program.Main(String[] args) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 92
Everything else updated except for the firmware, still on 3.0RC1
I noticed the Duet3Firmware_MB6HC.bin on the virtual SD card had today's timestamp so I ran M997 and it updated, now it shows 3.0RC2+1
I had that happened as well.
If you run M997 S0, the firmware is still updated -
@jay_s_uk said in RepRapFirmware 3.0RC2 now available:
If you run M997 S0, the firmware is still updatedYep, I was just doing an edit. That's exactly what I did.
Error code 16 means Device or resource busy. From what version did you upgrade?
@chrishamm RC2
I mean from what DSF version
@chrishamm said in RepRapFirmware 3.0RC2 now available:
I was coming from DSF version 1.2.1.0 with with 3.0RC1
Unpacking duetsoftwareframework (1.2.2.0) over (1.2.1.0) Unpacking reprapfirmware (1.2.2.0-1) over (1.2.1.0-1) Unpacking duettools (1.2.2.0) over (1.2.1.0) Unpacking duetcontrolserver (1.2.2.0) over (1.2.1.0) Unpacking duetruntime (1.2.2.0) over (1.2.1.0)
@chrishamm 1.2.1.0 for me too
I see, thanks. I'll try to reproduce that.
I had the same behavior (although I did not capture the error) when moving from Beta 12 to RC1.
Same fix, M997 S0
@chrishamm same here too from rc1 to rc2
I believe I know why it's happening. I've added a delay to the RRF package script to work-around this problem. Please let me know if that fixes it.
