[DSF Extension] Exec On MCode (was: Shutdown SBC)
Exec On MCode v2.0
After a request on GitHub to also make the command to run configurable I have renamed the whole project to
execonmcode
and created a new release that will make the command configurable.It will also report the outcome of the command (success, error) back to DuetSoftwareFramework.
As usual it can be found at GitHub Releases page.
Usage
$ ./execonmcode --help Usage of ./execonmcode: -command string Command to execute -mCode int Code that will initiate execution of the command (default 7722) -socketPath string Path to socket (default "/var/run/duet.sock")
@wilriker Great work, the plugin works just as it should!
We're using it to build a 'move backwards in gcode' function. However, it would be great if we could bring variables into the command string, maybe that could be solved by giving the M code S, P and Q parameters that would translate into $S, $P and $Q? -
@too Thanks! I saw your GitHub issue but was a bit busy the last days. Sorry for not getting back to you sooner. Also great to hear that it is actually used by someone other than myself.
I'll think about how to do that best.
@wilriker Now RRF3 just needs to be working smooth with some of the more exotic features and the system would be near perfection
@too said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
I expect to release RRF3 RC1 very soon.
@dc42 looking forward!
Release v2.1
This release provides parameter substitution. Please see the below for details on how to use it.
It can be found at the GitHub Releases page.
Parameters
execonmcode
does provide a simple mechanism for parameter substitution. It is possible to pass string parameters to the
selectedM-Code
and have them inserted in the-command
. In the command string they have to be single letters prefixed by
the percent-sign (%
) and they must not beG
,M
orT
.All parameters that do not have a corresponding value in the
M-Code
will be forwarded as given.Example
Run
execonmcode
as$ ./execonmcode -command "mycommand %F %N %D"
Then you can use the following
M-Code
syntax to replace these parametersM7722 F"my first parameter" N"my second parameter"
this will lead to an execution of
mycommand "my first parameter" "my second parameter" %D
Note that
%D
was passed as is since it was not given in theM-Code
Release v2.1.1
This is just a bug fix release to address a bug where too many (empty) parameters where introduced in between the command and it's actual parameters. This could lead to various problems.
Thanks to @too for reporting this.
Just as a short teaser: the upcoming version will allow an arbitrary amount of
M-code
+command
pairs. -
great Job !! many thanks.
exactly what I looked forTobias
Release v3.0
This release adds the possibility to provide an arbitrary amount of
-mCode
+-command
tuples. This way it is possible to have a single instance ofexeconmcode
handle all the custom commands.Note that as part of this change there is no longer a default value for
-mCode
.Get it at GitHub Releases page.
EDIT: This version is built agains
goduetapiclient
1.2.0 and as such will only work with DSF 1.2.2.1 and later. In case you need a version that is working with DSF <= 1.2.2.0 please tell me here. It's not a problem to provide that as well. -
@wilriker I can't believe I missed this whole thread! Gonna give it a try tomorrow.
I'm also working on something to allow the SBC to do a hardware reset and flash erase via GPIO pins for cases where the firmware is stuck and you can't get to the board. Could be a good companion to your utility.
@gtj0 Glad to hear about any use-cases.
I myself use it to run
poweroff
as well as activating and deactivating my webcam (starting/stopping asystemd
unit). -
Tempting to try with a small I2C OLED on the Pi, but not top of the list just yet
This sounds really good. I would like to use it to activate a bash script on my system but I have attempted to install it and I cant get it to work.
I followed your instructions in your first post but using execonmode V3:I downloaded execonmode and placed it into /usr/local/bin.
I tried to run it using sudo ./execonmode -help (just to see if it works) but I get the error message "cant open binary".Could you instruct me where i'm going wrong.
BTW I am on the latest version of RRF3 and up to date with DSF etc.
Thanks in advance.
@chas2706 If you run
sudo ./execonmcode -help
It will try to find the executable in the current directory you issue this command. To have your shell locate it in your
$PATH
remove the./
in front ofexeconmcode
. For-help
you don't needsudo
BTW.To make sure that it can find it also check if
echo $PATH
actually does contain
/use/local/bin
.Last thing: you spelled it
execonmode
instead ofexeconmcode
(extra "c" after "m") above. Make sure that's only a typo here. I might rename the executable in the future to something less error-prone. -
@wilriker
Thanks for the info. I will give it another go.execonmode was just a typo error in my post lol.
Thanks
@wilriker said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
./execonmcode -help
I have placed execonmcode in /usr/local/bin and typed the following in the terminal without success:
pi@Duet3:~ $ cd /usr/local/bin
pi@Duet3:/usr/local/bin $ ls
execonmcode listen-for-shutdown.py
pi@Duet3:/usr/local/bin $ ./execonmcode -help
bash: ./execonmcode: Permission denied
pi@Duet3:/usr/local/bin $ sudo ./execonmcode -help
sudo: ./execonmcode: command not found
pi@Duet3:/usr/local/bin $ execonmcode -help
bash: /usr/local/bin/execonmcode: Permission denied
pi@Duet3:/usr/local/bin $ sudo execonmcode -help
sudo: execonmcode: command not found
pi@Duet3:/usr/local/bin $ -
@chas2706 Have you made
execonmcode
executable viasudo chmod +x /usr/local/bin/execonmcode
? I think that's missing from the installation instructions. -
