G1 H1 X-355 F3000 does not work as expected
G1 H1 X-355 F3000 stops movement before reaching endstop when y < ~100. this makes homing unreliable.
what can i do to get this fixed? (except homing y first and move to y > ~200)
y does not suffer from this.
when properly homed x can be moved anywhere without any issues.
hw: duet 3 6hc rev 1.0
sw: FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0beta12 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2019-11-02b1conf: corexy printer
regards, gsp
@spllg how big is your printer?
Try increasing the -350 to a larger number. I use -999 in mine which is larger than my print size. -
Please upgrade your firmware to 3.0RC2.
@dc42 upgrading to 3.0RC2 made things worse:
after an initial failed x-home (from x=100,y=0, g1 h1 premature stopped at invisible endswitch) a subsequent x-home attempt (null-effect) did not terminate
after a successful x-home from (x=100,y=120) a z-home caused one spindle to move upwards while the other spindle did not move (dual z-steppers) resulting in a very ugly noise.
reverted to 3.0beta12
@jay_s_uk already have tried this - could not observe any change
@dc42 i feel, the problem might be related to micro step configuration as the y-threshold changes when i change micro step configuration (using m350 xnn ynn)
@spllg said in G1 H1 X-355 F3000 does not work as expected:
don't recall the specifics, but changes to microstepper or steps/mm after the other will affect the former. I.e. the order matters. show your config and I'm sure someone will spot any issues there.
Yes, please post your entire config.g
@Danal here it is
M550 P"3dd" ; set printer nameM667 S1 ; select CoreXY mode
M569 P0.0 S1 ; physical drive 0.0 goes forwards ; XY - right
M569 P0.1 S1 ; physical drive 0.1 goes forwards ; XY - left
M569 P0.2 S1 ; physical drive 0.2 goes forwards ; Zr
M569 P0.3 S1 ; physical drive 0.3 goes forwards ; Zl
M569 P0.4 S0 ; physical drive 0.3 goes forwards ; E0;M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
;M584 X0.0 Y0.1 Z0.3 E0.3 ; set drive mapping
M584 X0.0 Y0.1 Z0.2:3 E0.4 ; set drive mappingM350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
M92 X200.00 Y200.00 Z400.00 E420.00 ; set steps per mmM566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z3000.00 E3600.00 ; set maximum speeds (mm/min)M201 X500.00 Y500.00 Z25.00 E250.00 ; set accelerations (mm/s^2)
M208 X-26 Y0 Z0 S1 ; set axis minima
M208 X280 Y300 Z340 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io3.in" ; configure active-low endstop for low end on X via pin io3.in
M574 Y1 S1 P"io4.in" ; configure active-low endstop for low end on Y via pin io4.in
M574 Z1 S1 P"io5.in" ; configure active-low endstop for low end on Z via pin io5.in; bed leveling
;M671 X50:150 Y150:150 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis; ???
;M558 P1 C"io5.in" H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed; Z-Probe ( https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type )
;M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
;M557 X15:215 Y15:195 S20 ; define mesh gridM308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1; 2DO: fix and all below
M143 H0 S110 ; set temperature limit for heater 0 to 120C
M140 H0 ; map heated bed to heater 0M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit; Fans
M950 F0 C"out4" Q500 ; create fan 0 on pin out3 and set its frequency
M106 P0 H-1 ; set fan 0 value. Thermostatic control is turned off
;M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"out5" Q500 ; create fan 1 on pin out4 and set its frequency
M106 P1 S0 H-1 ; set fan 0 value. Thermostatic control is turned off
;M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@spllg The Z movement issue might be caused by this M584 X0.0 Y0.1 Z0.2:3 E0.4 which ought to be M584 X0.0 Y0.1 Z0.2:0.3 E0.4. Also, strictly speaking M667 is deprecated so M667 S1 ought to be M669 K1.
It might be an idea if you post your homing files too.
@deckingman changing the 2 suggested lines solved both issues - x-homing now works fine using 3.0RC2
thanks a lot
