VIN under-voltage event after connecting panelduedisplay
@vjsaini00 said in VIN under-voltage event after connecting panelduedisplay:
Supply voltage: min 2.4, current 3.9, max 32.2, under voltage events: 2524, over voltage events: 0, power good: no
what power supply have you got? the duet max supported is 25v.
how are you connecting the paneldue? via ribbon cable or 4 way cable?
the duet does not need the paneldue for operation. so disconnect it for now.
Thanks for replying, I am using 24v supply. I had already disconnected the paneldue, but still getting this error
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
Board ID: 08DGM-9T6BU-FG3SW-6J1FD-3SD6L-TVVZF
Used output buffers: 3 of 24 (8 max)
Static ram: 25712
Dynamic ram: 92836 of which 164 recycled
Exception stack ram used: 272
Never used ram: 12088
Tasks: NETWORK(ready,628) HEAT(blocked,912) MAIN(running,3736) IDLE(ready,160)
Owned mutexes:
Last reset 00:28:28 ago, cause: power up
Last software reset at 2019-12-23 16:01, reason: User, spinning module GCodes, available RAM 11468 bytes (slot 3)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 10
MCU temperature: min 23.4, current 25.6, max 26.3
Supply voltage: min 4.0, current 4.1, max 32.2, under voltage events: 111785, over voltage events: 6, power good: no
Date/time: 2019-12-23 21:34:17
Slowest loop: 6.28ms; fastest: 0.05ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.45ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address ec:fa:bc:31:78:aa
WiFi Vcc 3.33, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24056
WiFi IP address 192.168.1.21
WiFi signal strength -29dBm, reconnections 0, sleep mode m
- WiFi -
measure the voltage of the vin using a multimeter.
it is 24.17 v
disconnect everything except vin and gnd and test again.
I have already disconnected everything
what about the diagnostic leds? 3.3, 5v and vin. are they all lit up bright?
yes perfectly
are you aware that you have a clone board?
you will have to wait for an answer from @dc42 as to which component has failed.
i remember dc42 saying that the vin is calculated based on the 3.3v line.
but your 3.3v line must be fine as the cpu is working. -
ok thanks, I will wait for that..
THIS error shows up when duet 2 wifi connected to pc via usb
"Error: short-to-ground reported by driver(s) 0 2 3 4
Error: over temperature shutdown reported by driver(s) 0 2 3 4
Warning: VIN under-voltage event (0.3V)
12/24/2019, 12:10:23 AM Error: short-to-ground reported by driver(s) 0 1 2 3"Below are the diagnostics when duet 2 wifi connected through usb
M122
Static ram: 25712
Tasks: NETWORK(ready,764) HEAT(blocked,912) MAIN(running,3800) IDLE(ready,160)
Owned mutexes:
Last reset 00:00:37 ago, cause: power up
Error status: 0
MCU temperature: min 18.1, current 19.3, max 19.4
Supply voltage: min 0.2, current 0.2, max 28.0, under voltage events: 603, over voltage events: 0, power good: no
Driver 0: temperature-shutdown! short-to-ground standstill, SG min/max not available
Driver 1: temperature-shutdown! short-to-ground standstill, SG min/max not available
Driver 2: temperature-shutdown! short-to-ground standstill, SG min/max not available
Driver 3: temperature-shutdown! short-to-ground standstill, SG min/max not available
Driver 4: temperature-shutdown! short-to-ground standstill, SG min/max not available
Date/time: 2019-12-24 00:10:15
Cache data hit count 127774597
Slowest loop: 1.08ms; fastest: 0.05ms
=== DDARing ===
Segments left: 0
=== Network ===
Slowest loop: 15.40ms; fastest: 0.00ms
WiFi Vcc 3.34, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24144
WiFi signal strength -44dBm, reconnections 0, sleep mode modem
- WiFi -
Either the clone board is garbage, or the power supply is garbage. Either way, I think you're frying your board.
i think you have fried the drivers and they are now leaking current onto the 3.3v line.
@Veti
is there any way to confirm it? -
Error: over temperature shutdown reported by driver(s) 0 2 3 4that should not happen
@Veti said in VIN under-voltage event after connecting panelduedisplay:
But this only happens when I connect Duet2wifi through USB, otherwise, on 24v it only gives me vin under-voltage error
