Thermocouple issue with Duet3 6HC-3HC
18/12/2019 à 21:40:15 M308 S1 P"0.spi.cs0" Y" thermocouple-max31856" K"k"
No error reported18/12/2019 à 21:41:01 M308 S1
Sensor 1 type Thermocouple (MAX31856) using pin (spi.cs0,serial3.rx), reading 37.5, last error: success, thermocouple type K, reject 50Hz -
@steevebecker said in Thermocouple issue with Duet3 6HC-3HC:
Sensor 1 type Thermocouple (MAX31856) using pin (spi.cs0,serial3.rx), reading 37.5, last error: success, thermocouple type K, reject 50HzLooks like it's working then. Where are you seeing the 2000C readings? If you add a sensor name to the M308 command (A parameter) then you will be able to see the sensor temperature in the Extras tab of DWC, without having to assign a heater to use it.
Yes, I read 2000°C in DWC:
Tried that :
M308 S1 P"spi.cs0" A"TC0" Y"thermocouple-max31856" K"k"
It works!
I installed the thermocouple card on the EXP3HC (with the thermocouples wired) and ran a :
M308 S1 P"1.spi.cs0" A"TC0" Y"thermocouple-max31856" K"k"I get that :
M308 S1 :
Sensor 1 type Thermocouple (MAX31856) using pin 1.spi.cs0, last error: sensor short to other wiring, thermocouple type K, reject 50HzStrange, it is the same TC board and same wiring...
How... Sorry...
I thought that the limitation of the thermocouple that must be on the same card as the heater was fixed in version 3.0RC1It seems not.
It works with Thermistor but not with TC.If I setup the TC on 6HC and the heater on 6HC too, it works, DWC show the temperature.
Do you have any idea when this is going to be implemented?
(just to know if I'll have to change the TCs by Thermistors to do my tests at the beginning of the year) -
How... Sorry...
For safety reasons, I recommend that temperature sensors are connected to the same board as the heater. Currently, I believe a heater on the main board using a sensor on an expansion board works, but not the other way round.
I'm sorry, I misspoke. Actually, I want to use 2 heaters and 2 thermocouples with the EXP3HC card.
Do you think it should work? -
@steevebecker yes, if you have a prototype 3HC though most of them did not have the modification to make to temperature daughter boards work.
M308 S1 A"TC0" P"1.spi.cs0" Y"thermocouple-max31856" K"k"
Give no error but read 2000°C.
M308 S1
Sensor 1 type Thermocouple (MAX31856) using pin 1.spi.cs0, last error: sensor short to other wiring, thermocouple type K, reject 50HzYes, it is a prototype... bought in October.
Can I made the modification myself ? -
Can I made the modification myself ?Yes, here are the details.
It works fine, thank you...
The last thing is the Z Probe connected to the expansion board.
Do you have an idea when it will be supported ? -
Do you have an idea when it will be supported ?What type of Z probe is it?
It is a ZProbe we made ourself.
An electromagnet takes out a rod, on this rod is fixed a blade which hides or not a standard optical endstop.
