why did my Printer melt?
@Killernoy said in why did my Printer melt?:
@Phaedrux said in why did my Printer melt?:
every heater output is set to 100% at startup?
Every heater was on full power at startup?
Yes
correction not every just Bed and E2 E3 and E6
@dc42 I corrected myself it's only Bed, E2, E3 and E6
I now checked it and without the sd every heater is off
@Killernoy is it because you have inverted your heater pins?
Try removing the ! From each M950 command and try again -
@jay_s_uk said in why did my Printer melt?:
Try removing the ! From each M950 command and try againI will try that tomorrow thanks
I miss a few things in your config:
- PID settings
- Max Temp protection (M143)
Also the bedheat, e0heat and e1heat do not have to be inverted on duet2. If you do, then the heaters are always on.
The two heaters on duex5 a correctly that they have to be inverted.
According to you config there is no E6. You just have defined four extruders.
I also noticed you have defined
M950 H0 (Bed)
M950 H1 (Tool0)
M950 H2 (Tool1)
M950 H3 (Tool2)
M950 H4 (Tool3)but you create tools with:
M563 P0 H2
M563 P1 H3
M563 P2 H4
M563 P3 H5So the heater mapping does not match. That means if you gcode tries to heat up tool 1 it will heat up tool 2.
So your config is really confusing and I think this is the main reason why something is melted. The looks like you have done some mistakes while conversion to RRF3.
You can look at my config how to define 4 tools (I just picked the lines which are related for the tools):
; Drives M584 X0 Y1 Z2 E3:4:5:6 U7 ; Map Drives to Axis M669 K1 ; Select CoreXY mode M569 P0 S0 ; Drive 0 goes forwards M569 P1 S0 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S0 ; Drive 3 goes forwards M569 P4 S0 ; Drive 4 goes forwards M569 P5 S0 ; Drive 5 goes forwards M569 P6 S0 ; Drive 6 goes forwards M569 P7 S0 ; Drive 7 goes forwards M350 X16 Y16 Z16 E16:16:16:16 I1 ; Configure microstepping with interpolation M350 U8 I0 ; Configure microstepping without interpolation M92 X100 Y100 Z1600 U100 E460:460:460:460 ; Set steps per mm M566 X600 Y600 Z18 U2 E100:100:100:100 ; Set maximum instantaneous speed changes (mm/min) M203 X35000 Y35000 Z1200 U25000 E5000:5000:5000:5000 ; Set maximum speeds (mm/min) M201 X6000 Y6000 Z400 U500 E2500:2500:2500:2500 ; Set accelerations (mm/s^2) M906 X1650 Y1650 Z1100 U200 E1450:1450:1450:1450 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S120 ; Set idle timeout ; Thermal Sensors M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; Set thermistor + ADC parameters for heater 0 M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 1 M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 2 M308 S3 P"e2temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 3 M308 S4 P"e3temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 4 ; Hardware M950 H0 C"bedheat" T0 M950 H1 C"e0heat" T1 M950 H2 C"e1heat" T2 M950 H3 C"!exp.heater3" T3 M950 H4 C"!exp.heater4" T4 ; Max Temp Protection M143 H0 S140 ; Set temperature limit for heater 0 to 140C M143 H1 S270 ; Set temperature limit for heater 1 to 270C M143 H2 S270 ; Set temperature limit for heater 2 to 270C M143 H3 S270 ; Set temperature limit for heater 3 to 270C M143 H4 S270 ; Set temperature limit for heater 4 to 270C ; Tools M563 P0 D0 H1 F0 ; Define tool 0, Fan 0 M563 P1 D1 H2 F3 ; Define tool 1, Fan 3 M563 P2 D2 H3 F7 ; Define tool 2, Fan 7 M563 P3 D3 H4 F5 ; Define tool 3, Fan 5 ; PID Settings Tools M307 H1 A595.9 C199.5 D4.5 S1.00 V24.1 B0 ; Set PID settings tool 0 M307 H2 A775.0 C252.4 D8.2 S1.00 V24.1 B0 ; Set PID settings tool 1 M307 H3 A716.5 C237.1 D8.7 S1.00 V24.1 B0 ; Set PID settings tool 2 M307 H4 A567.7 C241.0 D6.7 S0.80 V24.1 B0 ; Set PID settings tool 3 M307 H0 A181.4 C631.5 D4.9 S1.00 V24.1 B0 ; Bed PID Settings ; Tooloffset G10 P0 X0.00 Y34.50 Z-15.84 ; Set tool 0 axis offsets G10 P1 X0.55 Y34.50 Z-15.83 ; Set tool 1 axis offsets G10 P2 X0.16 Y34.50 Z-15.85 ; Set tool 2 axis offsets G10 P3 X0.25 Y34.50 Z-15.70 ; Set tool 3 axis offsets ; Tools Temperatures G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C G10 P3 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C
This looks like a winner. Like swapping the gas and brakes pedals in a car.
@smoki3 said in why did my Printer melt?:
; Hardware
M950 H4 C"!exp.heater4" T4Although that will work, if you are using a DueX to provide heaters 3 and 4 then I would use this instead:
M950 H3 C"duex.e2heat" T3
M950 H4 C"duex.e3heat" T4You don't need to invert any heater pins if you use the actual pin names that you connect the heaters to.
I´m going through the configuration tool in order to avoid any further Problems
Thanks again to everyone that gave me advise for software.
I´m now set up with the config from the Tool, but the E6 LED is still lit up is this because i have my BLTouch on PWM5?
Yes.
Ok Thanks
