Another Mesh leveling thread…!
I did think about doing that but in the end settled for having:
G29 S1 ;load grid levelling mesh
M376 H10 ;taper off compensation after 10mm
M500At the end of my bed.g so it saves the calibration, and loads the grid and sets the taper off height. That way calibrations get progressively better. I just have to remember to run a grid levelling, which I have a macro for:
G29 S2 ;clear height map
M557 R140 S30 ;define levelling grid
G29 ;probe levelling grid save height map
G1 X0 Y0 Z100 F3000 ;reposition effectorIf I have moved the bed, or am running it at a different temperature etc…
That looks good to me. The G29 S2 is not needed, but harmless.
Nice! I might borrow most (all) of this!
I didn't even know that compensation taper existed… so there's that...
Thanks!,
-Casey -
Your welcome, I borrowed it off someone else here at some point.
Another Question!
Using G29 for bed leveling, does that move the Z physically like G32 does? Or does it handle the transform differently?
-Casey
Yes it moves the head in the Z direction to follow the contours of the bed.
I'm curious about a couple things with mesh bed leveling.
Does it move the head up and down to account for bumps or is it just a plane correction?
If you have a slight effector tilt (that is compensated for via H adjustments in the bed.g), how does the G29 command adjust for this (if at all?)
Thanks!!
G29 compensation moves the head up and down to follow the contours of the bed. Long moves get segmented into shorter ones to make this possible.
If you have varying Z probe trigger height due to effector tilt or anything else, currently the only way to compensate for it is to edit the height map file and reload it.
Would you do that the same way you do the h values in bed.g? For each point measured, calculate the difference from the center measurement and add/subtract it to the height map point?
Yes.
If you taper off with 10mm does that mean that it starts allready on second layer and has zero compensation at 10mm?
I did a G29 today after i printet a part on glass bed with glue on it. I had a huge error of 0.5mm where the printed part was peeled off compared to the rest of the bed. Normally it is within 0.1mm. Is this normal? Does it mean I only should run G29 with a washed glass plate? Really annoying as I sometimes have to take glass on/off for removing print and then I'd like to run G29 again to be sure it's seated the same as last time. Now I have to wash between every print
mesh leveling has caused me quite a lot of problems. I'm starting to wonder if it's really useful to me.
I've added G29 to my bed macro, and my slicer adds a G32 at the beginning of the gcode files.
Most of the time it works ok, but every now and then, at least once a day it fails. Probably because glass is not cleansed enough, or sometimes some bits of filament fell on the bed during the probes…
How about adding a new parameter to specify a acceptable deviation from G29 ?
My maximum deviations are often between -0.08 and 0.08. I'd love to be able to skip the whole G29 results if there are values outside of this range. (I guess I would also love RRP to cancel the print if G29 is triggered from a gcode file) -
Unless you are swapping bed plates around, why don't you use G29 S1 to load a known good height map instead of probing each time?
yes, that's what I thought.
I've been spending a lot of time playing with my duet, which is under the bed, so I decided to put G29 in bed macro. I guess I don't need it anymore.i guess I don't need to run G32 before every prints either.
