compiling paneldue firmware
I seen the previous topic about this but did not find answer so creating new one
Java: 13.0.1
Eclipse IDE for C/C++ Developers
Version: 2019-09 R (4.13.0)
Build id: 20190917-1200gcc-arm-none-eabi-9-2019-q4-major-win32
project does compile but:
01:29:08 Build Finished. 0 errors, 73986 warnings. (took 22s.452ms)
there's ton of:
this use of "defined" may not be portable [-Wexpansion-to-defined] 58 | #if (SAM3S || SAM4S || SAM4E)
and some "regular" warnings like:
../src/UserInterface.cpp:1151:4: warning: this statement may fall through [-Wimplicit-fallthrough=] 1151 | if (oldStatus != PrinterStatus::paused && oldStatus != PrinterStatus::resuming) | ^~ ../src/UserInterface.cpp:1157:3: note: here 1157 | case PrinterStatus::paused: | ^~~~ ../src/UserInterface.cpp:1172:23: warning: this statement may fall through [-Wimplicit-fallthrough=] 1172 | nameField->SetValue(machineName.c_str()); // if we are on the print tab then it may still be set to the file that was being printed | ~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~ ../src/UserInterface.cpp:1174:3: note: here 1174 | case PrinterStatus::configuring: | ^~~~
I don't mind warning (I'll easily add expansion-to-defined) but I just wanna be sure I set up the ENV properly and that I can trust this now
thanks
p.s. I know build.md advises oxygen but I was not able to make oxygen work properly with java 13.0.1 and I already have 20190917-1200 running
01:50:12 Build Finished. 0 errors, 34 warnings. (took 4s.53ms)
after I added
-Wno-expansion-to-defined
to gcc and g++ optionswhat's left is
[-Wformat-truncation=] [-Wimplicit-fallthrough=]
Those I guess are better left turned on
I use Eclipse 2019-09 and GNU Tools ARM Embedded 8-2019-q3-update. I don't see those warning messages. Looks like you are using a later version of gcc.
hi i have same setup as you and same warnings. when i flash the firmware everything is ok
@dc42 said in compiling paneldue firmware:
Interesting, I understood this is added to gcc7 so if you are using 8 it should be there too ..
anyhow looks like the setup is working, now to do something with it
A correction: for PanelDue i was using an older version of Eclipse and compiler 6 2017-q2-update. Looks like I didn't update the compiler for PanelDue when i updated it for RRF.
I've just updated it, and now I am getting those warnings too. I will look into it.
EDIT: most of those warnings are coming from ASF. We don't get those warnings when compiling CoreNG, which also uses ASF. So I suspect that updating to later ASF files will fix them. I don't have time to do this right now.
It turns out that PanelDue has "Extra warnings" checked in the C++ compiler settings as well as "All warnings". Turning off "Extra warnings" removes almost all those warnings.
that makes more sense, as it seems to be added to gcc7
