Nozzle gets smashed against the bed
@MJCT said in Nozzle gets smashed against the bed:
@fcwilt ~
Nop, last 2 times that that I sent G30 the nozzle smashed the bed
When that happened did the pin drop down at the start?
@fcwilt
Yes -
@fcwilt
YesDid the pin retract when it touched the bed?
It's possible you have an intermittent connection in the wires that carry the signal from the probe back to the Duet.
@fcwilt
Yes, the pin retract when it touches the bed -
@fcwilt
Yes, the pin retract when it touches the bedBut the motion did not stop?
When the pin is in the down position how far below the nozzle does it extend?
My last test returned this value
https://drive.google.com/file/d/1EH_a5huQdowrXaahItpsKx0ADAuLq9RX/view?usp=sharingshould I input
G31 P25 X25 Y0 Z0.229
or
G31 P25 X25 Y0 Z2.29 ?
@fcwilt said in Nozzle gets smashed against the bed:
When the pin is in the down position how far below the nozzle does it extend?Yes the motion stoped.
The pin gets +- 3.3mm below the nozle -
The pin gets +- 3.3mm below the nozleWell if the motion stopped how did the nozzle hit the bed?
And you enter the value just as displayed.
the problem now is that this thread is getting to long and I’m starting to get confused with all the questions. Kind off... you where asking about the G30, when I home the Z, When I start the machine....???
Well, I entered the value as displayed “G31 P25 X25 Y0 Z0.229”
Seems to work at the beginning. First layer a little bit far from bed, corrected it with baby steps, and printed the rest of the first layer fine.
Second layer moved a lot above what was expected and started to print in the air.
May be the “G31 P25 X25 Y0 Z0.229” was right from the beginning and the problem is Cura?
What other slicers do you use for reprap?Now I’m going home, long day! Thank you all, I really appreciate all your effort!
If it moved further than expected, have you got your z steps correct for your machine?
M92 X80.00 Y80.00 Z4000.00 E96.94 ; set steps per mm
Z steps per mm of 4000 doesn't sound correct.
Z_steps_per_mm = (motor_steps_per_rev * driver_microstep) / screw_lead
@jay_s_uk said in Nozzle gets smashed against the bed:
Yes, I tested it before I started asking questions. Any way If you read this
"Well, I entered the value as displayed “G31 P25 X25 Y0 Z0.229”Seems to work at the beginning. First layer a little bit far from bed, corrected it with baby steps, and printed the rest of the first layer fine.
Second layer moved a lot above what was expected and started to print in the air."
you know that the problem is not Z steps
Please fill out the formula above for determining Z steps per mm and show how you arrive at 4000. Thanks.
@Phaedrux
I tried to use the formula when I was using the config tool, but that value was provided by the manufacturer. But I will double cheek it tomorrow -
Who is the manufacturer? What type of printer is this?
@Phaedrux said in Nozzle gets smashed against the bed:
More on that tomorrow, I prefer to confirm first everything I say about a company on the web. It would be terribly unfair for them if I was making some kind of confusion.
The printer is a core XY based on V rails -
That does not sound right. For a typical 8mm lead and 1.8 steppers the steps/mm would be 400. 4000 would mean a 0.8mm lead which doesn't seem likely.
4000 is the default value in the configurator.
this value was used for one the first 3d printers which used m5 threaded rods.here is a picture of the ones used some time ago.
https://www.instructables.com/id/3D-Printer-Lead-Screw-Upgrade/most modern 3d printers now use a 4 start lead screw with a 8mm pitch which results in 400 steps per mm.
if your printer really has one of the old ones, you should swap that out before you do any prints, as it will result it very poor prints.
also you have a beta value of 4138. this is also the defaults and most likely wrong for your thermistor.
you need to find the correct value, otherwise you are printing at the wrong temperature.
