Error: Cannot read file, error code 1. Cancelled printing...
@nz_andy, upgrade your firmware to 2.02. It includes retry code for when SD card errors occur.
Both of you, I suggest you replace the SD card.
I replaced the SD card. It has worked perfectly since.
I tested the "bad" SD card on my PC using some SD card testing software. It ran flawlessly for a week (I forgot I had started it).
But I still threw it away.
I have the same problem, I have already burned a lot of plastic for this problem and I don't know what else to do, change SD, install and reinstall to 2.04, the welds are fine ... what can I do?
I also read this post
https://forum.duet3d.com/topic/6788/cannot-read-file-error-code-1 -
@domingo said in Error: Cannot read file, error code 1. Cancelled printing...:
https://forum.duet3d.com/topic/6788/cannot-read-file-error-code-1Are you saying that you get this error even when using firmware 2.04 and a new SD card?
@dc42 unfortunately, the prints always stop at the same point, replace the SD card with a newly purchased one and reinstall all the software, check the connector welds, reconnect and check all the wiring, I don't know what else to try
Does it give the same error if you run the print in simulation mode?
@dc42 if I just tried several models and in simulation they end well,I've tried again in normal mode and I have another half piece Now I have a horde of turtles
@domingo, which firmware version are you using?
@domingo, is this still a problem? if so, please report which firmware version you are using.
@dc42 RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
Thanks. There a chance (although not a large one I admit!) that changes to DMA handling in firmware 2.05RC1 may have fixed this, so please try that version.
I have this issue on my list to resolve in the 2.05 firmware release.
@dc42 ok, I update now to 2.05rc1 and I am telling you the progress, thank you very much for the great work and support
Thanks for that information. Please let me know immediately if the problem returns. For now I will treat it as fixed.
@dc42 of course I would let you know, for now, after the last update, the two pieces went well
Hello @dc42 , upgrade from Release 2.05RC1 to Release 2.05RC2 and I have the same problems again.
This is possible?
any solution? -
@dc42 ohh the bug has returned in Release 2.05 final
@domingo, is this still a problem? Are you running firmware 2.05.1 now?
