da Vinci Jr. 1.0
Thanks again for info.I all already read this,sound Like JR hitting wall.
Just to summarise the idea:
*Reuse the Board
*Cannibalise the board-to rid off unnecessarily chips .
*Use fly wires “soldering “ to make connections
*Make it us much as Duet WiFi as possible
*Add WiFi modulebolded textitalicised textHelp required it just basic pin swap in source files (What files to edit for pins swap?)to match stepper drivers, end stops, thermistor and heater signals (pins).Very basic requirement to kick jr printer live. Jr can live without lcd .sd card slot should Mach pins anyway?!
SOS LoL
What files to edit for pin swap???
!!!Marlin was easy edit pins.h!!! ,and that’s it .
Is this the same with RRF???or Duet WiFi“Let of the chest:Nothing personal”
“Rant
Lack of 4x20 or4x16 support??? And keypad?.
No videos on websites from duet creators with simple basic Tutorials -who is dreaming about duet3?? Duet2 is fancy enough!!!.
Why not spread the word about duet2 WiFi (Video support) and lower original board price to increase community.
“Board overpriced”!!!
Is where to many flavours in compile folder?!?and makes everything confusing.”Once again nothing personal...
Thanks
@ViralTinker said in da Vinci Jr. 1.0:
Is this the same with RRF???or Duet WiFino, because RRF is specific for the duet.
there is a lpc port of RRF
https://github.com/sdavi/RepRapFirmware/tree/v2-dev-lpc/EdgeRelease/ExampleBoardConfig
which has support for the popular skr v1.3.@ViralTinker said in da Vinci Jr. 1.0:
there are a lot of tutorials on how to set up the duet on youtube
as well as a good guide like this https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37Why not spread the word about duet2 WiFi
i dont think there are many people that have invested time into 3d printing that have not heard about the duet.
the duet hast the paneldue
the maestro supports the standard 12864 lcd. why would you want 4x20 support? -
@Veti why would you want 4x20 support? Because junior printer has
well you have your work cut out for you.
i dont think you will find a lot of people that are interested in doing this, as the price of the davinci board is more than the duet.
https://3dprintersuperstore.com.au/products/motherboard-for-da-vinci -
@Veti oh did not see this,yes it is ripoff price..
The pin definitions are in two places:
- File CoreNG/variants/DuetNG/variant.cpp describes the capabilities of each pin. You would only need to change this file if you want to use a pin for a special function (e.g. a serial interface, or SPI interface) and the Duet doesn't use that pin for that function.
- The main pin definition is in file RepRapFirmware/src/DuetNG/Pins_DuetNG.h.
@dc42 And “NG” stads for?...
"Next Generation", the code name we used for the Duet WiFi before we announced it.
Thank you
@ViralTinker
Forgot to ask ,what for is chip next to WiFi module connected together?is it for reset?
@ViralTinker
It's to detect the leading edge of the chip select signal from the WiFi module and cancel the data request. It could probably be eliminated by changing the firmware on the WiFi module, however when I wrote the firmware for that module, the documentation of the ESP8266 was so poor that it wasn't clear whether the chip supported edge-triggered interrupts or not.
Thanks a lot
