Connecting multiple Z probes for multiple independent Z axis
@dc42 since the extruders are independent, and z axis and x axis will also be independent. we will need two probes right?!
@georgepaul said in Connecting multiple Z probes for multiple independent Z axis:
ZideX
I think I see what you mean. That printer design has two independent extruders, each on its own X carriage, and the height of each X carriage is controlled by a separate Z motor. Correct?
In RepRapFirmware 2 you can switch between different types of Z probe using M558, and some types have their own G31 settings. RepRapFirmware 3 will be more versatile. You can already configure multiple Z probes in RRF3 (each with its own type and G31 parameters), all that's missing is a new M-code to switch between them.
With either firmware, you can use the tool change files to select the Z probe you want to use and to switch height maps.
what about on the hardware side... where can i put the additional probe pins?
On Duet 2 you can connect digital-output Z probes to any endstop input as well as to the Z probe connector. On Duet 3 you can connect them to any of the nine IO_x connectors.
so even a capacitive probe, working on 12V will not harm the Duet if the signal pin of probe is connected to any endstop STP pin.
only on a duet2 v1.04 and up
mine says;
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.0(RTOS) ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2018-06-05b3so I guess it's not compatible!
the firmware can not see which hardware revision you have, at those changes are independant of the firmware.
its printed on the pcb
ok then im safe... my hardware says Duet2 V1.04... yippie
Ok so i did connect a Zprobe and got it working. I made the following changes and it worked for the NPN inductive sensor that I scavenged.
I made the following wiring. I used the IN4007 because i dint have anything else on me.
The following config changes were done;
**; Endstops
M574 X1 Y1 U1 S0 ; Set active low and disabled endstops
M574 Z1 S2; Z-Probe
M558 P1 I1 H5 F120 T6000
M557 X25:0 Y25:0 S20 ; Define mesh grid**and it worked fine.
Then i tried using theProbe for the U axis and i made this tiny change in the config.g file;
M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops
M574 U1 S2And that too worked fine
my doubt is whether this can be done;
and if i wanted to connect two probes can one more be connected in the E0 endstop STP pin for the U axis?
i am just making sure i don't fry the board by doing something wrong
