RepRapFirmware 3.0 first official beta is out
As you can see here the drivers are detecting the stall very well.
https://photos.app.goo.gl/DMTiBbvibGsSs42Y7
But it looks like the signal get not processed correctly.
Testing yesterday and today has so far shown 1.0.4.0 to be stable, and fixed the quality issue that cropped up in 1.0.3.5
@smoki3 said in RepRapFirmware 3.0 first official beta is out:
If I put a G92 X"xx.xx" in the homing scipt than it is working as it should
@wilriker , any chance I can look at your duet2 config files for RRF3, your machine is close to mine and I'm just getting ready to try RRF3?
@stewwy Yeah, no problem. I can provide it to you tomorrow. But be warned the post I link to in my signature is a bit outdated.
This post is deleted! -
Hi, could someone look at these, from my config.g and see if they are correct for RRF3?
M574 X1 S1 P"xstop" ; X home to min.
M574 Y2 S0 P"ystop" ; Y home to max. N0pen micro-switches.
M574 Z1 S2 P"zprobe.in" ; Define Z to use DC42 irProbe. Home to Min.;ZProbe
M558 P1 C"zprobe.in" H3 F600 T6000 X0 Y0 Z1 ; Set Z probe type/mode 1. Not using on XY, but using it on Z. F400 dive speed T6000 travel speed
G31 P500 X15 Y-2 Z1.46 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
M671 X-50:325 Y110:110 S0.5 ; Leadscrew positions for bed trammingThanks in advance
Edit: I should mention I am using 2 motors for Z
@dc42 please don't take this the wrong way, but just for some planning purposes.. when do you think the next release will be out?
@triumphantduke said in RepRapFirmware 3.0 first official beta is out:
Soon, perhaps tomorrow.
@stewwy said in RepRapFirmware 3.0 first official beta is out:
If you are using G30 commands to home Z in your homing files, you should remove the M574 Z command, because you have no Z endstop switch.
@dc42 haha okay, standing by eagerly
