Bed levelling (G32 S3) skips the final move and probe
I have found that explicit move speed values are usually advisable.
Also you don't that M561 - G29 S2 does the same thing and is preferred.
As to the other issues I need some clarification please:
Why are you doing G32 S3?
Why are you doing that G1 X2 Y2 near the middle of bed.g?
Why are you doing that G28 XY at the end of bed.g? You have already done a plain G28 above homing X,Y & Z.
What happens if you use M400 to ensure the moves are completed?
Also is this the latest firmware and DSF? I had a similar issue with an older version of DSF
@fcwilt said in Bed levelling (G32 S3) skips the final move and probe:
Yep but this bed.g file worked perfectly on my Duet2 even with RRF3 so something's different.
True, but doing both is safe.
- Why are you doing G32 S3?
That was actually a copy and paste error. I don't actually do the S3.
- Why are you doing that G1 X2 Y2 near the middle of bed.g?
It's not the middle it's just after the homing and I was testing moving the tool off of the endstops.
- Why are you doing that G28 XY at the end of bed.g? You have already done a plain G28 above homing X,Y & Z.
No reason other than moving the tool back to 0,0.
@T3P3Tony said in Bed levelling (G32 S3) skips the final move and probe:
Yep, M400 worked. I'm using DSF 1.1.0.0. Maybe an old bug crept back in?
OK so now the moves are completing but the correction never converges. The leadscrews are being adjusted but they keep moving in the wrong direction. I'm wondering if the adjustment magnitudes are correct but maybe the signs are being applied backwards.
Leadscrew adjustments made: -0.052 -0.252 -0.448, points used 3, deviation before 0.285 after 0.000
Leadscrew adjustments made: -0.030 -0.427 -0.819, points used 3, deviation before 0.506 after 0.000
Leadscrew adjustments made: 0.008 -0.773 -1.562, points used 3, deviation before 0.948 after 0.000
manually moved leadscrew 1 to bring the bed further away from the nozzle.
Leadscrew adjustments made: 0.051 -0.813 -2.292, points used 3, deviation before 1.317 after 0.000
Leadscrew adjustments made: 0.149 -2.160 -4.496, points used 3, deviation before 2.705 after 0.000
The bed is quite tilted now. -
@gtj0 If your leadscrews adjust in the wrong direction the most likely thing is that you have your stepper wires in the wrong ports. Pay careful attention that:
- your leadscrew definition is the the correct order for your driver connections
and - your leadscrew location definitions match that order.
For mine my leadscrews are arranged like this:
1 2 0
and are plugged into drivers 2, 3, 4 so my config is:
M584 X0 Y1 Z2:3:4 E5 ; Map X to drive 0 Y to drive 1, Z to drives 2, 3, 4, and E to drive 5
M671 X-10:-10:283 Y22.5:227.5:125 S7.5Also note the drivers on the duet3 are in this physical order
0 1 2
5 4 3Hope this helps!
Duh. The first and third motors were reverse. I'm going back to bed.
Thanks @kraegar ! -
Are you guys upvoting the fact that I'm an idiot???
Nope - we are just glad to hear you got it working.
We've all made foolish mistakes from time to time.
I knew what it was right away, because I get this exact question on our printers about twice a week or so. It's an easy mistake to make!
Actually, when I was mounting the Duet3 I made a mental note that the drive connectors were ordered clockwise from the top left. I just couldn't find it when I was hooking up the connectors.
@gtj0 nope, just adding to your karma
