Updating Firmware on Duet 3?
Thank you! The problem is/was that the download renamed the file "Duet3Firmware_MB6HC.bin" to "Duet3Firmware.bin", yet the M997 command wanted "Duet3Firmware_MB6HC.bin". I renamed it back, and then manually issued "M997 S0". This worked.
Btw, DWC reports the firmware version as "3.0beta10 (2019-09-12b1)", yet people refer the newest version as 1.0.4.0. ?
1.0.4.0 is the current version of DuetSoftwareFramework, the software running on the SBC in the non-standalone mode.
@JuKu said in Updating Firmware on Duet 3?:
Old versions of DWC do this renaming because they don't know about the new naming convention for RRF on Duet 3. So you need to upload the firmware file, decline the invitation to install it, then send M997.
Btw I find that the IAP for Duet 3 isn't yet 100% reliable, so sometimes I have to resort to USB and Bossa.
USB and Bossa seems to be the only way that works with the current versions of the DSF and firmware. When you execute M997, you get
M997 S0 Error: Failed to find IAP file /opt/dsf/sd/sys/Duet3iap_spi_MB6HC.bin
Duet3iap_spi_MB6HC.bin isn't in the distribution.
Pretty simple to use usb and bossa with
M999 PERASE
, no need to manually use the erase jumper. But ofc DWC is even simpler -
@gtj0 said in Updating Firmware on Duet 3?:
That file should be included. I'll follow that up.
This file together with some others has been moved from
duetsd
to the new additional packagereprapfirmware
. It seems that documentation has not yet caught up. -
@wilriker said in Updating Firmware on Duet 3?:
duetsd
. It seems that documentation has not yet caught up.I see the deb package added in DSF but I'm not seeing the bin file nor any means to create it.
@gtj0 AFAIK it's auto-generated by a filesystem watchdog on the package server.
Well that's not too open-source friendly.
@brendon
apt saidpi@duet3:~ $ sudo apt-get upgrade The following packages have been kept back: duetsoftwareframework
so i said
pi@duet3:~ $ sudo apt-get upgrade duetsoftwareframework Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following NEW packages will be installed: reprapfirmware The following packages have been kept back: libgl1-mesa-dri mesa-va-drivers mesa-vdpau-drivers The following packages will be upgraded: duetsoftwareframework 1 upgraded, 1 newly installed, 0 to remove and 3 not upgraded. Need to get 433 kB of archives. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] y Get:1 https://pkg.duet3d.com unstable/armv7 armhf reprapfirmware all 1.1.0.1-1 [431 kB] Get:2 https://pkg.duet3d.com unstable/armv7 armhf duetsoftwareframework armhf 1.1.0.1 [1,706 B] Fetched 433 kB in 1s (520 kB/s) Reading changelogs... Done Selecting previously unselected package reprapfirmware. (Reading database ... 75827 files and directories currently installed.) Preparing to unpack .../reprapfirmware_1.1.0.1-1_all.deb ... Unpacking reprapfirmware (1.1.0.1-1) ... Preparing to unpack .../duetsoftwareframework_1.1.0.1_armhf.deb ... Unpacking duetsoftwareframework (1.1.0.1) over (1.0.3.3) ... Setting up reprapfirmware (1.1.0.1-1) ... Sending update request to DCS... Done! Setting up duetsoftwareframework (1.1.0.1) ... pi@duet3:~ $ echo M115 | sudo /opt/dsf/bin/CodeConsole Connected! FIRMWARE_NAME: RepRapFirmware for Duet 3 v0.5 FIRMWARE_VERSION: 3.0beta10+2 ELECTRONICS: Duet 3 prototype v0.5 FIRMWARE_DATE: 2019-09-28b1 pi@duet3: $ ls /opt/dsf/sd/sys config.g Duet3Firmware_TOOL1LC_11.bin Duet3iap_spi_MBP05.bin Duet3Firmware_EXP3HC.bin Duet3Firmware_TOOL1LC.bin dwc2settings.json Duet3Firmware_MB6HC.bin Duet3iap_sd_MB6HC.bin Duet3Firmware_MBP05.bin Duet3iap_spi_MB6HC.bin
which seems to have sorted it out and upgraded the firmware all one go
Interesting, I didn't see the
message. I ran the suggested code and it looks like the firmware is all up to date! Thanks for the support!!!
