Solved Change the Router Duet WiFi don't work (ok but....)
Hi i had read some documentation about this.
I know perfectly that changing the SSID and WPA duet can't connect to the network, so I describe what I had do:Disable 5ghz WiFi on router, after that i remove SD card and replace M587 in the config file with the new SSID and WPA but after i read that isn't the right way to do that, so:
I connect Duet with the Terminal (Mac OS) with USB cable, I turned off the wifi with M552 S-1, after turn on WiFi M552 S0 i put new M587 with only new SSID and WPA after that i put the command M552 S1. But still not working.
I try to wait 10 minute to wait that Duet enter in access point mode but can't go.
What can I do? Maybe i make something wrong or not in the right order.
Many thanks!
I had to remove the space in my SSID name for it to work and make it all caps, since I was using proterface.
This post is deleted! -
@cts5191 Thanks but my SSID name don't have any space and all caps... Thanks...
I had the same issue, change your wifi security so that you force only WPA2 PSK, dont use mixed mode. You can then use 2 and 5G without any issues.
@Shaun OH many thanks I'll give it a try!
@Shaun You find the problem, I had disable mixed mode and now work fine!!!
Many Thanks cheers!
