Firmware Quad Colors
@bandulaadrian said in Firmware Quad Colors:
but it does not work
You will have to be more specific than that.
Here's what I last used:link textThanks
Hello
I have a question,why does this temperature show me?
It may be because they are not connected the extruder and bed. .Thanks
Yes, it probably means that the temperature sensors are not connected.
Thanks
It was really because I didn't connect the extruder and bed.I'm trying to do some tests now.
Thanks again
Hello
How can I change motor direction for home .
Thanks
Are the motors moving the wrong way when you jog them (you can enable jogging before homing by sending M564 H0); or are they moving in the correct directions but trying to home at max instead of min (or vice versa)?
Hello
They were even heading in the wrong direction,I checked the connectors, I reversed them and now its OK.
Thank you very much
The other way to change motor directions is to change S0 to S1 or vice versa in the M569 commands in config.g.
When I connect the printer gives me this answer:
I do not understand why, because it is the fourth time I want to use it.
Thank you for any help
