Duet 3 Mainboard 6HC - initial production run.
yep the Duet has the 26 and the pi is 40
Aug 10th were some comments in this thread about to use other cables if necessary.
@T3P3Tony Can we still use the link in the first post to order even though there might not be any available from the first run?
@gtj0 now just yet. I want to be able to say when the next batc will be available first
Tony is there any chance any more from this first batch will become available I know at least one guy who is desperate to jump on the band waggon. I seem to remember you saying you had kept some back to allow for failures during testing
Doug
I suppose there is no way to be notified when some stock is available? I have cash in hand for a D3 Mainboard, but missed the pre-order. I don't want to miss the chance to purchase on because I didn't check the website at the right time. So Doug told me to post a comment here as well.
Looking forward to this!
@Dougal1957 I expect we will do, will announce more next week.
@T3P3Tony said in Duet 3 Mainboard 6HC - initial production run.:
Thanks I will point him to this.
@Dougal1957 said in Duet 3 Mainboard 6HC - initial production run.:
Tell him to get to the back of the line.
It's a little hard to tell from the renderings and pics but can someone confirm that the 26 pin connector polarity notch faces in towards the MPU?
@gtj0 said in Duet 3 Mainboard 6HC - initial production run.:
Did you see the new Wiki? https://duet3d.dozuki.com/Wiki/SBC_Setup_for_Duet_3
@bearer Yeah but you can't tell in those pics because the cable exits the IDC pins to the left (inwards) but then loops back through the strain relief towards the right and out. I can't see the notch.
@gtj0 I suppose its not given the notch is on the left hand side in those pictures although the red stripe indicating pin 1 would suggest that, which side the cable exits shouldn't affect pin 1 and the notch.
I've learned through bitter experience not to take for granted the relationship between the notch and pin 1. About 10 years ago I had a local company make me 100 10-pin cables and they didn't bother to follow my spec. Apparently 3 different people made the cables so I got 3 different orientations.
Anyway, I'm experimenting with different cable lengths and right now I'm getting great results with a 300mm cable at a 1MHz clock rate but only if I alternate the signal lines with grounds. In fact it still looks great at 5HMz. I was toying with using some twisted pair as well but twisted pairs aren't all that effective in unbalanced circuits.
@gtj0 the 26 way header notch goes in, towards the center of the Duet 3 mainboard. The Duet 3 has a keyed header.
Perfect. Thanks @T3P3Tony And what are you doing up so late?
Mine is here! Yay!
From reading this thread, and the new wiki, it is a little unclear to me if the included SD card is should already have an image on it. The one I received formatted, but empty. Installing the image now...
Edit update: Image installed, booted, connected via both Web and SSH, everything works just fine. Now, to pick a printer to receive this beauty...
Danal
Mine certainly had an image on else I would have been lost as I know very little about the way Linux interacts (I know a lot more now since I got this thing on Saturday)
Doug
Doug
Did the Duet 3 just get classified as a "gateway drug"?
@Danal it should have had the image, glad you got it working!
