Deleting Gcode files on micro sd card
Is there anyway to delete gcode files on the sd card without removing the card from the duet?
https://duet3d.dozuki.com/Wiki/Gcode#Section_M30_Delete_a_file_on_the_SD_card
or use duet web control
@bearer Thx for the link. I havent found a way to delete from DWC
right click a file entry?
(screenshot from dwc2) -
@bearer OK found it, right click filename!
@brian said in Deleting Gcode files on micro sd card:
You can delete a bunch at once by checking the boxes next to them and right clicking on one of them.
Considering that gcode files are typically used as temporary local copies for the printing process, would be nice to be able to enable a global time to leave. E.g. delete gcode files that have not been used for 3 days.
