New RepRapFirmware 3.0 early beta
@dc42 I switched now back to 2.02.
Here is everything fine. Also 2.04 and 2.03 has this issue. I tried also the old v3 build from the dropbox. Here also everthing is fine.
I assume that it has something to do with the commits from May 25th.
I will later do a build an try it out -
I was trying to build a older build but it seems that it's necessary to build wifisocketserver. But I don't geht it to build in my mac
This is now on my list to investigate, and fix in 2.04 if I can confirm the problem.
@smoki3 said in New RepRapFirmware 3.0 early beta:
I was trying to build a older build but it seems that it's necessary to build wifisocketserver. But I don't get it to build in my mac
You don't need to build wifisocketserver, you just need the include directory in it to be present in the Eclipse workspace.
@dc42 using the tip of the current RRF v3-dev...
Sent: M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 C0 R4700 Sent: M308 S0 Sensor 0 type Thermistor using pin bedtemp, last error: sensor not ready, T:100000.0 B:4138.0 C:0.00e+0 R:4700.0 L:0 H:0 Sent: M308 S2 Y"thermistor" P"e1temp" A"HotEnd" T100000 B4725 C7.06e-8 Sent: M308 S2 Sensor 2 (HotEnd) type Thermistor using pin e1temp, last error: sensor not ready, T:100000.0 B:4725.0 C:7.06e-8 R:4700.0 L:0 H:0
Is there something wrong with this M308 syntax? All temps are 2000.0
@dc42 said in New RepRapFirmware 3.0 early beta:
I always get this when I trying to compile from a older source. If I try the actual branch everything is fine
../src/Networking/ESP8266WiFi/WiFiInterface.cpp:1857:10: error: 'APIN_SPI_MISO' was not declared in this scope make: *** [src/Networking/ESP8266WiFi/WiFiInterface.o] Error 1
@smoki3 You have to make sure that all of the repositories are at about the same point in time to compile. Most of the times having all repos except RepRapFirmware at the latest commit works but every once in a while there are bigger changes across repos (as in the case you show where some constants had been renamed) that require you to revert the according repo (I think it is CoreNG in this case) to a commit prior to the breaking change.
I have done some further testing:If I put not only "G1 X76" at the beginning of the tpre rather a "G1 X76 Y165" (Y165 same Y position as tfree) then just the X axis and Z axis is moving and Y axis stays as it should. Anyway the Z axis shouldnt move at this point.
So if you don't but every single axis into the first command of tfree it will restore the old position of the tool head
@wilriker said in New RepRapFirmware 3.0 early beta:
That's right, the APIN_SPI_MISO message means that the RepRapFirmware project is not in sync with CoreNG.
@gtj0 said in New RepRapFirmware 3.0 early beta:
There are some reported bugs in the current v3-dev. In particular, you need a quarter second delay between creating a sensor using M308 and creating a heater that uses it. I also have a report that configuring thermistors using M308 doesn't work (at least on Duet 3), which I am about to investigate.
No problem. Thanks!
If there's anything I can do to help, let me know. Specific bugs needing to be squashed, testing, etc. -
I've just committed new source code to fix a number of RRF3 bugs, including issues with temperature readings.
Yep, temps now read correctly. Thanks!
It was definitely not like this on 2.02 and the older 3.0.And its a really wired behaviour. Because I use:
; tfree0.g ; called when tool 0 is freed ; ; generated by RepRapFirmware Configuration Tool on Wed Sep 19 2018 21:12:53 GMT+0200 (Mitteleuropäische Sommerzeit) G91 G1 Z10 F7200 G90 G53 G1 X0 F25000 ;XPOS G53 G1 Y190 G53 G1 Y195 F5000 M400 M98 P"/macros/Toolhead/1. Toolhead unlock" G4 P320 G53 G1 Y207 F5000 M400 G53 G1 Y165 F25000 M400
; tpre1.g ; called before tool 0 is selected ; ; generated by RepRapFirmware Configuration Tool on Wed Sep 19 2018 21:12:53 GMT+0200 (Mitteleuropäische Sommerzeit) G1 X76 F25000 M400 G1 Y192 M400 M98 P"/macros/Toolhead/1. Toolhead unlock" G4 P400 G1 Y207 F5000 M116 P3 M400 M98 P"/macros/Toolhead/2. Toolhead lock" G4 P260 G1 Y150 F15000
The I only expect that only a X movement is done while the start of the tpre1.g but it first moves in X and Y.
@smoki3, I am looking into this but I need your config.g file, also the toolhead unlock files that you call from the tool change files.
@dc42 I will provide it until next week. I am on vacation
@dc42 Homing seems to be broken at the moment.
If the axis is already homed and it's endstop is triggered, you can't run the homing sequence again without getting aError: G0/G1: insufficient axes homed
and the axis changing state to unhomed.Example... Here's my CoreXY homex.g file...
G91 ; relative positioning G1 H1 X-490 F3600 ; move quickly to X axis endstop and stop there (first pass) G1 X5 F3600 ; go back a few mm G1 H1 X-490 F360 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning
If the endstop isn't triggered the homing sequence runs. If it's already homed, I get the error.
Also, when it does work, it sometimes reports the tool at a small distance from 0. For instance, if I home X, sometimes the tool is reported at 0.000, sometimes, 0.105, sometimes 0.038, etc.
Oh, here's another one. I'm not sure of this is related to the tool offset discussion but when RRF initializes, the Z axis height displays the offset from the heightmap so as you move the X or Y axes, the Z axis position display changes.
Too bad the duet forum can't be merged with like a Discord server, that would be pretty cool and pretty convenient with how you can like tag or pin people or everyone in that particular thread, I'd be way more active on a Discord server, just saying, phone mobile notifications for the discord app are kinda nice, I have it notify my only when someone specifically tags me.
Not sure if you're interested in this at all, but I have have access to a few industrial machines, I found a way to get the list of the supported G-Codes and M-Codes in Fanuc's controllers. I have access to a 2014 Doosan Puma GT2100 CNC lathe and idk what year Doosan DNM 5700 mill and a very large and rather new Haas GR712 and two ProtoTrak controllers.
Perhaps I'm unfamiliar with the specific intent of the Duet 3.0, but I vaguely remember a conversation with you about standardizing the G-Codes at least, as M-Codes tend to be manufacturer and/or machine application specific. I'll get lists/pictures of all the G-Codes and M-Codes if you want and if there's any other information you want/need from the Fanuc controllers (kinda wanna reverse engineer their controller myself cuz they are the standard for industrial CNC controllers). It's for several networking and interface ports, can't imagine it would be that hard to get code from the controllers:)
Anything you wanna know about some of the industrial controllers we have in our shop??
Oh, and this is something cool I discovered is Macro B Programming on Fanuc controllers. Click here for a PDF on my Google drive about Macro B Programming inside Fanuc controllers
It allows parametric hand programming for canned cycles like G71 on a CNC lathe which is a roughing operation.
link to pictures of my program I created in a couple minutes
@noskillzengineer said in New RepRapFirmware 3.0 early beta:
I for one would object to this very much, for several reasons:
- The T&C for using Discord are "all your comments belong to us".
- Mobile devices with their ultra slow on-screen keyboards are an incredibly frustrating experience for reading and creating textual and graphic content. Give me a computer with a proper keyboard every time.
- Things like Discord servers and F***book are awful for storing information in a form where you can search for it and organise it in a structured way. They might be good for people with an attention span of minutes, but not for structured discussions.
- Discord and other such platforms are not indexed by web search engines, making any information that they hold even more inaccessible.
@dc42 Just FYI... The current v3-dev RRF branch isn't building for the Duet2...
arm-none-eabi-gcc -L"/usr/src/3d/dc42/workspace/CoreNG/SAM4E8E" -L"/usr/src/3d/dc42/workspace/CoreNG/SAM4E8E" -L"/usr/src/3d/dc42/workspace/FreeRTOS/SAM4E" -L"/usr/src/3d/dc42/workspace/RRFLibraries/SAM4E_RTOS" -Os --specs=nano.specs -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -T"/usr/src/3d/dc42/workspace/CoreNG/variants/duetNG/linker_scripts/gcc/flash.ld" -Wl,-Map,"/usr/src/3d/dc42/workspace/RepRapFirmware/Duet2_RTOS/Duet2CombinedFirmware.map" -o "Duet2CombinedFirmware.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "/usr/src/3d/dc42/workspace/CoreNG/SAM4E8E/cores/arduino/syscalls.o" ./src/Tools/Filament.o ./src/Tools/Spindle.o ./src/Tools/Tool.o ./src/Storage/CRC32.o ./src/Storage/FileInfoParser.o ./src/Storage/FileStore.o ./src/Storage/MassStorage.o ./src/ObjectModel/ObjectModel.o ./src/Networking/W5500Ethernet/Wiznet/Internet/DHCP/dhcp.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/W5500/w5500.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/WizSpi.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/socketlib.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/wizchip_conf.o ./src/Networking/W5500Ethernet/W5500Interface.o ./src/Networking/W5500Ethernet/W5500Socket.o ./src/Networking/ESP8266WiFi/WiFiInterface.o ./src/Networking/ESP8266WiFi/WiFiSocket.o ./src/Networking/ESP8266WiFi/WifiFirmwareUploader.o ./src/Networking/FirmwareUpdater.o ./src/Networking/FtpResponder.o ./src/Networking/HttpResponder.o ./src/Networking/Network.o ./src/Networking/NetworkBuffer.o ./src/Networking/NetworkResponder.o ./src/Networking/TelnetResponder.o ./src/Networking/UploadingNetworkResponder.o ./src/Movement/StepperDrivers/DriverMode.o ./src/Movement/StepperDrivers/TMC22xx.o ./src/Movement/StepperDrivers/TMC2660.o ./src/Movement/StepperDrivers/TMC51xx.o ./src/Movement/Kinematics/CoreKinematics.o ./src/Movement/Kinematics/HangprinterKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/PolarKinematics.o ./src/Movement/Kinematics/RotaryDeltaKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/Kinematics/ZLeadscrewKinematics.o ./src/Movement/HeightControl/HeightController.o ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o ./src/Movement/DDA.o ./src/Movement/DDARing.o ./src/Movement/DriveMovement.o ./src/Movement/Move.o ./src/Movement/RawMove.o ./src/Movement/StepTimer.o ./src/Libraries/sha1/sha1.o ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Libraries/Fatfs/ffunicode.o ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/DhtSensor.o ./src/Heating/Sensors/LinearAnalogSensor.o ./src/Heating/Sensors/RemoteSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SensorWithPort.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/Heater.o ./src/Heating/HeaterProtection.o ./src/Heating/LocalHeater.o ./src/Heating/RemoteHeater.o ./src/Heating/TemperatureError.o ./src/Hardware/DmacManager.o ./src/Hardware/I2C.o ./src/Hardware/IoPorts.o ./src/GCodes/GCodeBuffer/BinaryParser.o ./src/GCodes/GCodeBuffer/GCodeBuffer.o ./src/GCodes/GCodeBuffer/StringParser.o ./src/GCodes/GCodeChannel.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/GCodes/GCodes3.o ./src/GCodes/GCodes4.o ./src/GCodes/RestorePoint.o ./src/GCodes/Trigger.o ./src/FilamentMonitors/Duet3DFilamentMonitor.o ./src/FilamentMonitors/FilamentMonitor.o ./src/FilamentMonitors/LaserFilamentMonitor.o ./src/FilamentMonitors/PulsedFilamentMonitor.o ./src/FilamentMonitors/RotatingMagnetFilamentMonitor.o ./src/FilamentMonitors/SimpleFilamentMonitor.o ./src/Fans/DotStarLed.o ./src/Fans/Fan.o ./src/Endstops/Endstop.o ./src/Endstops/EndstopsManager.o ./src/Endstops/ZProbe.o ./src/Endstops/ZProbeProgrammer.o ./src/DuetNG/DueXn.o ./src/DuetNG/Pins_DuetNG.o ./src/DuetNG/SX1509.o ./src/Display/ST7920/glcd11x14.o ./src/Display/ST7920/glcd7x11.o ./src/Display/ST7920/lcd7920.o ./src/Display/Display.o ./src/Display/Menu.o ./src/Display/MenuItem.o ./src/Display/RotaryEncoder.o ./src/CAN/CanInterface.o ./src/CAN/CanMessageGenericConstructor.o ./src/CAN/CanMotion.o ./src/CAN/CommandProcessor.o ./src/Logger.o ./src/OutputMemory.o ./src/Platform.o ./src/PortControl.o ./src/PrintMonitor.o ./src/RepRap.o ./src/RepRapFirmware.o ./src/Roland.o ./src/Scanner.o ./src/SoftTimer.o ./src/Tasks.o -lCoreNG -lCoreNG -lFreeRTOS -lRRFLibraries -Wl,--end-group -lm /opt/x-tools/gcc-arm-none-eabi-8-2018-q4-major/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld: ./src/RepRap.o: in function `RepRap::GetStatusCharacter() const': RepRap.cpp:(.text._ZNK6RepRap18GetStatusCharacterEv+0x26): warning: undefined reference to `Platform::HasVinPower() const
Could you update us on which branches of the various projects currently go together for the Duet2 and Duet3 and which configurations go together for the Duet3 as I can't get that to build either.
Also, there's a typo in src/Heating/RemoteHeater.cpp
#include <CanMessageformats.h>
should be
#include <CanMessageFormats.h>
@grizewald Hmmm, I didn't know that about the comments and content. I also was not considering the retrieval of information or the storing of it, I was thinking purely communication specific. I use Swype for my phone and there is no way I can type faster on a keyboard, no way. A phone, specifically an android one, also utilizes Google's Talk-To-Text which you can more or less speak normally and it'll beat most far typers with minimal errors in most dialects, with exceptions of course. Just a quick thought, I don't care to go into chrome and logon each time and go to the website specifically to go into the forum. Their own app (built with flutter) could also be an alternative. ¯_(ツ)_/¯
