Microstepping suggestions, explanation?
S3d definitely needs an upgrade.
In the beginning I thought it was smart of them to have zero customer contact so they could concentrate on development.
Now starting to wonder what pressures (if not customers) will help iron out the quirks of their interface and propel functionality to another level?
Tried it a few times but that was version 3.0.0 and it seemed to make some bizarre choices of non printing moves compared to slic3r which is my daily drive. Plus it should be called Complicate3d.
…................ Plus it should be called Complicate3d.
Made me chuckle - I'll second that observation though. They do however, honour their 30 day refund policy which was the best feature of it IMO.
Well I tried a "trial" version if you know what I mean but wasn't taken by it. I figured I'd opt for the full software if it was going to do what I wanted, but I couldn't find an easy way to switch from layout for one printer to another, so as I have a bunch of them it wasn't going to work.
It was multi colour that screwed it for me. Two colour was just about doable but 3 was a nightmare. I have done 10 colour using slic3r, just for the hell of it, and it's a breeze (although it doesn't do wipe or prime towers though). S3D does do prime towers - it prints the tower, then changes the tool and continues with the print. (huh?). I never did get an answer from them as to why they found it necessary to purge the tool when it was finished with but not before it was about to be used.
I think what they will do is just move to a new major version and ask everyone to fork out more money. I'm very disappointed in the rate they are releasing anything at all, I mean the product next to never gets updates and it has a ton of problems. It's almost as if they look around and say, nobody is on our heals so we can slow to a crawl.
What version are you actually using.
I have had 2 updates since I purchased it 6 months ago?
3.1.1 , for a company with a single purpose in life 2 updates in 6 months is really bad.
Yeah I can see where your coming from.
They also seem to implement things in strange way's such as firmware retraction they have used deprecated codes for it as far as I can tell it is only Teacup that supports it (Tho the Duet does as well now)
