Have to restart for first layer to be correct
Yes sir, All of that (PID, Extrusion, ETC...) was done. I will leave bed.g as the entire frame, bed frame too is printed so I may need to change to G31 instead of G29 S1 in my script. If you would like to see the printer I have the entire build on YT. Kuntry3D on YT let me know what you think. I had to re-flow the solder for the main DC power in on the Duet this morning as that was what was causing my failures due to voltage inconsistencies. Once I fxed that my voltage is steady and everything is now sorted. Thank you for all of your help, you have been very patient with me and my questions.
No problem at all. Glad it's all working out. I'll definitely check out your channel.
@phaedrux said in Have to restart for first layer to be correct:
Grasping at straws here, but is there a reason you've chosen 32 microstepping as opposed to 16 with interpolation to 256?
I just saw this.
"Grasping at straws here, but is there a reason you've chosen 32 microstepping as opposed to 16 with interpolation to 256?"Can you tell me how to do this?
The M350 command in your config.
Simply change it to 16 and add I1 (that's a letter I as in I love you man)
Your steps per mm should already be set for 16 microstepping as the duet will make adjustments for you if you change it after. But double check just to be sure.
Give this section a read it'll have some more detail but I think you're good to go.
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Movement_section -
Thank you sir
