Display bed temperature
I have successfully added a bed temperature sensor to my Modix Big-60. I can read the temp with M308 and can see it in the web interface. I would like to see it on the machines display panel, I’ve searched and searched to find how to edit the display panel content but just cannot seem to find any info, I’m probably using the wrong keywords
where can I find this info? Thanks.
@scooby The PanelDue only shows temperatures related to heaters, ie nozzles, beds and chambers. If your bed temperature sensor isn't used by a heater (ie usually the bed heater), it will show on the 'Extras' tab in DWC only. You can define a 'dummy' heater, that uses an unused output, and map the temperature sensor to that, and define it as a bed or chamber. See https://docs.duet3d.com/User_manual/Connecting_hardware/Heaters_bed#configuring-a-bed-heater
