Gcode upload with python and OpenAPI
I am trying to write a Python program to control a Duet 3 mainboard 6HC via Ethernet. I am using the OpenAPI definition for standalone mode. Everything works well except for the file upload function.
When I run my test program, I get this error message:
File Path exists: True
Exception when calling DefaultApi->rr_upload_post: (0)
Reason: Cannot prepare a request message for provided arguments. Please check that your arguments match declared content type.Does anyone have any idea what I am doing wrong?
Here is my test program:
#! /usr/bin/python3 # -*- coding: utf-8 -*- """ Duet file upload test """ from __future__ import print_function import os from datetime import datetime import swagger_client from swagger_client.rest import ApiException from pprint import pprint """ create an instance of the API class and connect Duet to fixed host address DUET_HOST """ configuration = swagger_client.Configuration() configuration.host = "http://192.168.2.1" # instance of the API class api_instance = swagger_client.DefaultApi(swagger_client.ApiClient(configuration)) time = datetime.now() try: # new connection and log in duet_response = api_instance.rr_connect_get(password="", time=time) except ApiException as e: print("Exception when calling DefaultApi->rr_connect_get: %s\n" % e) # Upload a file file = "f:/temp/test.g" print("File Path exists: ", os.path.exists(file)) try: duet_response = api_instance.rr_upload_post(file) except ApiException as e: print("Exception when calling DefaultApi->rr_upload_post: %s\n" % e) # Disconnect Duet try: duet_response = api_instance.rr_disconnect_get() # pprint(duet_response) except ApiException as e: print("Exception when calling DefaultApi->rr_disconnect_get: %s\n" % e)
@cnc65 which version of the firmware are you using? Are you using the same version of the api yaml file in swagger to generate the api code. e.g. 3.6 is here for stand alone mode:
https://github.com/Duet3D/RepRapFirmware/blob/3.6-dev/Developer-documentation/OpenAPI.yaml -
RepRapFirmware: 3.5.4
OpenAPI yaml: 3.6 and also tested with 3.4 -
@cnc65 I am not a python expert but I used swagger to generate a python api using 3.6.0.
Looking at that code for your error message i found it in "rest.py":
def request(self, method, url, query_params=None, headers=None, body=None, post_params=None, _preload_content=True, _request_timeout=None): """Perform requests. :param method: http request method :param url: http request url :param query_params: query parameters in the url :param headers: http request headers :param body: request json body, for `application/json` :param post_params: request post parameters, `application/x-www-form-urlencoded` and `multipart/form-data` :param _preload_content: if False, the urllib3.HTTPResponse object will be returned without reading/decoding response data. Default is True. :param _request_timeout: timeout setting for this request. If one number provided, it will be total request timeout. It can also be a pair (tuple) of (connection, read) timeouts. """ method = method.upper() assert method in ['GET', 'HEAD', 'DELETE', 'POST', 'PUT', 'PATCH', 'OPTIONS'] if post_params and body: raise ValueError( "body parameter cannot be used with post_params parameter." ) post_params = post_params or {} headers = headers or {} timeout = None if _request_timeout: if isinstance(_request_timeout, (int, ) if six.PY3 else (int, long)): # noqa: E501,F821 timeout = urllib3.Timeout(total=_request_timeout) elif (isinstance(_request_timeout, tuple) and len(_request_timeout) == 2): timeout = urllib3.Timeout( connect=_request_timeout[0], read=_request_timeout[1]) if 'Content-Type' not in headers: headers['Content-Type'] = 'application/json' try: # For `POST`, `PUT`, `PATCH`, `OPTIONS`, `DELETE` if method in ['POST', 'PUT', 'PATCH', 'OPTIONS', 'DELETE']: if query_params: url += '?' + urlencode(query_params) if re.search('json', headers['Content-Type'], re.IGNORECASE): request_body = '{}' if body is not None: request_body = json.dumps(body) r = self.pool_manager.request( method, url, body=request_body, preload_content=_preload_content, timeout=timeout, headers=headers) elif headers['Content-Type'] == 'application/x-www-form-urlencoded': # noqa: E501 r = self.pool_manager.request( method, url, fields=post_params, encode_multipart=False, preload_content=_preload_content, timeout=timeout, headers=headers) elif headers['Content-Type'] == 'multipart/form-data': # must del headers['Content-Type'], or the correct # Content-Type which generated by urllib3 will be # overwritten. del headers['Content-Type'] r = self.pool_manager.request( method, url, fields=post_params, encode_multipart=True, preload_content=_preload_content, timeout=timeout, headers=headers) # Pass a `string` parameter directly in the body to support # other content types than Json when `body` argument is # provided in serialized form elif isinstance(body, str): request_body = body r = self.pool_manager.request( method, url, body=request_body, preload_content=_preload_content, timeout=timeout, headers=headers) else: # Cannot generate the request from given parameters msg = """Cannot prepare a request message for provided arguments. Please check that your arguments match declared content type.""" raise ApiException(status=0, reason=msg) # For `GET`, `HEAD` .....
Does that shed any light on why its failing?
Things to try:
Use the CURL commands as a test in the documentation here;
https://github.com/Duet3D/RepRapFirmware/wiki/HTTP-requests#post-rr_upload
That proves the duet side of thingsHave thieving on the same version (preferably 3.6, so for RRF use 3.6beta4)
@T3P3Tony Thank you for your help.
What I have tried so far:- Update RRF to 3.6beta4
- Test CURL commands:
F:\temp>curl http://192.168.2.1/rr_connect?password= {"err":0,"sessionTimeout":8000,"boardType":"duet3mb6hc102","apiLevel":2,"sessionKey":0} F:\temp>curl --data-binary @"test.g" "http://192.168.2.1/rr_upload?name=/gcodes/test.g" {"err":0} F:\temp>
No success with Python so far.
What I dont understand is that the Python function generated from OpenAPI has only one parameter "name". The parameters "time" and "crc32" are optional. But at least two variables are required: source(path_and_filename.gcode) and destination(name) like in CURL.
rr_upload_post
Example
from __future__ import print_function import time import swagger_client from swagger_client.rest import ApiException from pprint import pprint # create an instance of the API class api_instance = swagger_client.DefaultApi() name = 'name_example' # str | Path to the file to upload time = '2013-10-20T19:20:30+01:00' # datetime | ISO8601-like represenation of the time the file was last modified (optional) crc32 = 'crc32_example' # str | CRC32 checksum of the file content as hex string *without* leading `0x`. Usage of this parameter is encouraged (optional) try: # Upload a file api_response = api_instance.rr_upload_post(name, time=time, crc32=crc32) pprint(api_response) except ApiException as e: print("Exception when calling DefaultApi->rr_upload_post: %s\n" % e)
Parameters
Name Type Description Notes name str Path to the file to upload time datetime ISO8601-like represenation of the time the file was last modified [optional] crc32 str CRC32 checksum of the file content as hex string without leading `0x`. Usage of this parameter is encouraged [optional] -
@cnc65 said in Gcode upload with python and OpenAPI:
so curl is working, there is an issue with the python implementation or the API description in YAML file
What I don't understand is that the Python function generated from OpenAPI has only one parameter "name". The parameters "time" and "crc32" are optional. But at least two variables are required: source(path_and_filename.gcode) and destination(name) like in CURL.
I think the "name" parameter is the destination path & filename. however the comments in the YAML file imply its the source:
parameters: - name: 'name' in: query description: 'Path to the file to upload' required: true schema: type: string - name: 'time' in: query description: 'ISO8601-like represenation of the time the file was last modified' required: false schema: type: string format: 'date-time' - name: 'crc32' in: query description: 'CRC32 checksum of the file content as hex string *without* leading `0x`. Usage of this parameter is encouraged' required: false schema: type: string
@chrishamm can you help?
Is a solution to this problem in progress?
undefined cnc65 marked this topic as a question
@chrishamm can you point to where it is in the API definition? I.e. where is "body" is specified in the definition?
@chrishamm thanks so this is some issue with swagger?
@T3P3Tony Perhaps it was the GET request, not the POST request? I'm not sure.
@chrishamm I looked at the swagger post code.
@chrishamm @T3P3Tony
I have changed the requestBody in the OpenAPI.yaml file so that a parameter body is generated in Python. This works for uploading gcode files. I have not tested other files.requestBody: required: true description: 'File content' content: application/octet-stream: schema: type: string format: binary
The function call in Python then looks like this:
# Upload a file file = "f:/temp/test.g" name = "0:/gcodes/test-1.g" try: body = open(file).read() duet_response = api_instance.rr_upload_post(body, name) except ApiException as e: print("Exception when calling DefaultApi->rr_upload_post: %s\n" % e)
undefined cnc65 has marked this topic as solved
