Connecting Orca slicer to DWC 3.5.4
I can access DWC from pretty much any web interface. Orca slice has an embedded browser in the Device tab that lets you directly connect to the printer and manage it.
I added my IP address to Orca slicer and it says connection successful. On the device tab I see DWC interface, it is updating correctly, but I cannot interact with any of the UI.
There is a field for Device UI, but it says only use that if different from the host name. I copied it there anyway but the results are the same.
Anyone see similar and find solution? At least I can watch print progress.
Well that was quick. I found if I right click there is a reload menu which caused it to come alive. All works great now! Hope this helps someone else.
